    GetViewInfo
    3 Posts 2 Posters 532 Views 2 Watching
    • N Offline
      N Lindenthal
      GetViewInfo
      SU6:
      Wie kann ich in SU6 von einer eingestellten bestimmten Sicht folgende Parameter ermitteln:
      SU6:
      How can I get the following parameter:
      Latitude
      Longitude
      Hight
      Distance
      Tilt
      Azimuth
        Jim
        Hello,
        Look at the ShadowInfo object:
        http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-shadowinfo.html
        Some of the values may need calculated from what is available:
        Sketchup.active_model.shadow_info.keys
        ["City", "Country", "Dark", "DayOfYear", "DaylightSavings", "DisplayNorth", "DisplayOnAllFaces", "DisplayOnGroundPlane", "DisplayShadows", "EdgesCastShadows", "Latitude", "Light", "Longitude", "NorthAngle", "ShadowTime", "ShadowTime_time_t", "SunDirection", "SunRise", "SunRise_time_t", "SunSet", "SunSet_time_t", "TZOffset", "UseSunForAllShading"]
        latitude = Sketchup.active_model.shadow_info["Latitude"]
        • N Offline
          N Lindenthal
          Thanks, Jim.
          set konsolenText to "DayOfYear = Sketchup.active_model.shadow_info[\"DayOfYear\" ]"
          tell application "SketchUp"
          	activate
          	tell application "System Events"
          		tell process "SketchUp" --stellt im Konsolentextfeld die Einfügemarke sicher
          			tell menu bar 1
          				tell menu bar item "Fenster"
          					tell menu 1
          						click menu item "Ruby-Konsole"
          					end tell
          				end tell
          			end tell
          		end tell
          		keystroke konsolenText --to "AXTextFiled" of "Ruby-Konsole"		keystroke return
          	end tell
          end tell
          Because I start an AppleScript script from FileMaker, I need not to type in ruby console.
          With ruby script above I get
          162 (when the date of shadow is 06/11)
          163 (when the date of shadow is 06/12)
          But for Longitide, Latitude I got no different values, if I turn or go some steps, but only 10 and 50 (my location).
          So my question, how I can set the parameter of my view to get back a view of remember, stays here.
