    Sunken ship
    13 Posts 6 Posters 1.6k Views 6 Watching
      tomislavm
      Thank you, this is an picture from internet and I could not find better!
        dolphus
        Well done very original like the sunlight in the water πŸ‘
          gigga97
          If you dont mind me asking......How did you get hte under water effect and is it possible with kerkythea? thnx and great renders πŸ‘
          PC SPECS:
          Q6600 @ 3.0Ghz
          2x 9800GTX+'s in dual SLI
          4GB G.Skill Ram
          EVGA 750i FTW edition MOBO
          • FrederikF Offline
            Frederik
            I don't know how much tomislavm knows about KT... These have been rendered in Hypershot... πŸ˜‰
            Besides, I assume that the rays in the above renders have been made in a post pro... 😐
            But the answer to your question is Yes... πŸ˜„ Please take a look at the kt under water thread... πŸ˜‰
            To make this effect you need to render using caustics and volumetric light...
            ❗ But be aware that it's not easy to achieve such renders..!!
            There's a lot of pitfalls and most will do this in a post pro, since it's much easier... πŸ˜‰
            Cheers
            Kim Frederik
              gigga97
              Thanks frederik i will take a look at the link πŸ‘
              PC SPECS:
              Q6600 @ 3.0Ghz
              4GB G.Skill Ram
                tomislavm
                1. I took a picture from internet.
                2. I broke my model in two parts.
                3. Open Hypershot and import background picture.
                4. Directly import sketchup model, rotate model in Hypershot and render.
                • FrederikF Offline
                  Frederik
                  And you didn't add anything to the render in a post pro..?? πŸ˜•
                  (Like the bubbles and the cloud of dust from the "impact"...)
                  Can you post the original image used (the picture you got from the internet)..?? πŸ˜‰
                  Cheers
                  Kim Frederik
                    tomislavm
                    Only wires,bubbles and sand around ship, I will send you original picture later!
                      tomislavm
                      This is the picture I have use for background in my render
                      • FrederikF Offline
                        Frederik
                        Thanks, tomislavm..!! πŸ˜‰
                        I'm sure that some will try to use it and render their own underwater scene... πŸ˜„
                        Cheers
                        Kim Frederik
