    SDS & FFD Abstract Sculptures with Interesting Textures
    38 Posts 15 Posters 7.8k Views 15 Watching
    • K
      kwistenbiebel
      Love'em !
      • F
        fbartels
        Just a couple more. One, a final export from last night in which I removed the screen "shadow" shapes, and the other from a quick experiment using follow-me to create the proxy shape to feed into SdS. Quite a bit of potential there I think. (Chris.. btw, I enjoyed your original pre self-censored comment. 😉 😄 )
        http://dws.editme.com/files/Home/sds last one v7.jpg
        http://dws.editme.com/files/Home/sds 8 v2 sm.jpg
        • ___olo_
          ___olo
          I have a litte question, how do you paint the map on your model ???
          Xin chào nhau giữa con đường
          Mùa xuân phía trước, miên trường phía sau
          • F
            fbartels
            Hi _olo,
            The steps to project a texture are...
            1. Bring an image into your model and position it as you want relative to your geometry. Be aware that after sampling, the image in essence projects out at 90 degrees from the plane of the image surface.
            2. Once you have the image where you want it relative to the geometry you want to paint then select the paint bucket tool while holding down the Command key (on a Mac) and click on the image. This samples the image. (If you haven't already exploded the image you will need to do this.)
            3. Then let go of the Command key (or Windows equivalent) and click on the geometry you want to paint. If the geometry is grouped, or a component, then you want to enter the group/component and select everything you want to paint before painting with the bucket tool.
            A trick I use is to extrude the image to make sure it completely covers the geometry I want to paint. If it doesn't, use the Scale tool to resize the entire extruded box until it encloses the geometry. The two images below should help make this clearer. The SU file used to make the images, which it too large to upload here, is available at the bottom of this page.
            • F
              fbartels
              This one turned out looking quite glassy. Kinda cool. Some of you in Holland may recognize the place in the image that I used for the texture.
              • T
                twharvey
                [attachment=1:1qnq3rb6]<!-- ia1 -->ex 1.jpg<!-- ia1 -->[/attachment:1qnq3rb6]
                [attachment=0:1qnq3rb6]<!-- ia0 -->projection example 2 .jpg<!-- ia0 -->[/attachment:1qnq3rb6]
                Fred,
                I downloaded your SU file and tried it. I guess I still don't understand what you did.
                1. How do you apply the texture to the object when it inside the extruded texture image?
                2. When I extruded the image, the sides of the box were just parallel stripes (as Normal)so that when I tried to paint them on my object (a cylindar) all I got was the same stripes.
                Thanks in advance,
                Tom
                Tom
                • F
                  fbartels
                  Tom,
                  I made a quick video tutorial which should make this all crystal clear.
                  It is fairly large and will take a few moments to download.
                  It is located here.
                  Fred
                    Cool video ☀
                    Are you the cousin of Niki de Saint Phalle? 😉
                    • K
                      kwistenbiebel
                      Indeed, I always loved those statues and fountain of De Saint Phalle over at the Centre Pompidou in Paris.
                      Are those still there?
                      • F
                        fbartels
                        Pilou,
                        I think Niki de Saint Phalle would have really liked SketchUp and LOVED SdS and FFD.
                        There are some interesting videos of her garden in Tuscany here.
                        I just read through her Wikipedia page. She was quite the character.
                        Thanks for pointing her out!
                        Fred
                        • T
                          twharvey
                          @fbartels said:
                          Tom,
                          It is located here.
                          Fred
                          Fred,
                          Thanks. I followed your video and got a good result! 👍
                          Tom
                          Tom
                            I am not sure if the big piece is still there, maybe yes 😄
                            Tinguely +Nikki = joyous mood ☀
                            http://www.productionmyarts.com/Images/architecture-musees/paris/paris-centre-georges-pompidou-fontaine-detail.jpg
                            at flickr 😉
                            • MarianM
                              Marian
                              Hi Fred, scouring the warehouse i found this little interesting bit of information.
                              http://img7.pictiger.com/775/15558598_th.jpg
                              So...you were a Sketchup nut about 40 years before most of us 😄
                              • K
                                kwistenbiebel
                                That's funny.
                                It must have been the age Sketchup was still in black & white. 😄
                                • I
                                  igor
                                  its from when dinosaurs romed the earth! (sorry to all the 38 year olds for making you feel old.)
                                  that must've been an error, google has probably fixed it by now. or was that really posted in 1970?
                                  suddenly, it's 1970. (car nuts will understand)
                                  oh, and LOL.
                                  The genius switch has no "off" position
                                  Intelegence is natrual, it takes real effort to be ignorant
                                  • F
                                    fbartels
                                    You'd think I would have progressed more in 40 years. 😞
                                    • ___olo_
                                      ___olo
                                      @fbartels said:
                                      Hi _olo,
                                      Thanks Fbartet. I have done as you talk, and it's very cool.
                                      And this is my pic.
                                      http://i254.photobucket.com/albums/hh95/champion1102/thoivang.jpg
                                      • GaieusG
                                        @igor said:
                                        ...sorry to all the 38 year olds for making you feel old...
                                        I can't even remember that age 😒
                                        • 2 / 2
