    SDS & FFD Abstract Sculptures with Interesting Textures
    38 Posts 15 Posters 7.5k Views 15 Watching
    • F Offline
      fbartels
      Chris... I agree about the limitations being a pain, I just try to work within/around them.
      Pete... I really, really, really need to find the time to learn how to do rendering. 😞
      Some new ones. I've got to stop this.
      http://dws.editme.com/files/MayJune2008/ttt 4 v2.jpg
      http://dws.editme.com/files/MayJune2008/ttt 4 v1.jpg
      http://dws.editme.com/files/MayJune2008/ttt 4 v4.jpg
      • I Offline
        igor
        no! dont stop! these are awsome. i especialy like those last ones, they remind me of glass with stripes of colored glass inlayed with it.
        and if you cant find the time to learn how to render stuff, just use podium. its as intuitive and easy to learn as SU. plus its pretty dang fast.
        i serriously need to get this pluggin.
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
          remus
          Those last ones are very cool fred, i look forward to you learning to render, i tihnk we could have some interestign stuff being posted 😄
            Can you use some texture like this or must it be tiling seamless?
            (here Zbrush doodling)you can find some on my "Speedy galerie" free to you to use them 😉
            • E Offline
              ehaflett
              Great stuff Fred, your posts never disappoint and always entertain.
                lapx
                Great images Fred don't stop posting please!
                • F Offline
                  fbartels
                  Thanks all, for the kind comments. One more experiment.
                  http://dws.editme.com/files/MayJune2008/sds last one v5.jpg
                  http://dws.editme.com/files/MayJune2008/sds last one v4.jpg
                  http://dws.editme.com/files/MayJune2008/sds last one v3.jpg
                  http://dws.editme.com/files/MayJune2008/sds last one v1.jpg
                  • soloS Offline
                    oooh! that looks like one of the deep ocean creatures from the BBC Planet earth series.
                      kwistenbiebel
                      Love'em !
                      • F Offline
                        fbartels
                        Just a couple more. One, a final export from last night in which I removed the screen "shadow" shapes, and the other from a quick experiment using follow-me to create the proxy shape to feed into SdS. Quite a bit of potential there I think. (Chris.. btw, I enjoyed your original pre self-censored comment. 😉 😄 )
                        http://dws.editme.com/files/Home/sds last one v7.jpg
                        http://dws.editme.com/files/Home/sds 8 v2 sm.jpg
                        • ___olo_ Offline
                          ___olo
                          I have a litte question, how do you paint the map on your model ???
                          Xin chào nhau giữa con đường
                          Mùa xuân phía trước, miên trường phía sau
                          • F Offline
                            fbartels
                            Hi _olo,
                            The steps to project a texture are...
                            1. Bring an image into your model and position it as you want relative to your geometry. Be aware that after sampling, the image in essence projects out at 90 degrees from the plane of the image surface.
                            2. Once you have the image where you want it relative to the geometry you want to paint then select the paint bucket tool while holding down the Command key (on a Mac) and click on the image. This samples the image. (If you haven't already exploded the image you will need to do this.)
                            3. Then let go of the Command key (or Windows equivalent) and click on the geometry you want to paint. If the geometry is grouped, or a component, then you want to enter the group/component and select everything you want to paint before painting with the bucket tool.
                            A trick I use is to extrude the image to make sure it completely covers the geometry I want to paint. If it doesn't, use the Scale tool to resize the entire extruded box until it encloses the geometry. The two images below should help make this clearer. The SU file used to make the images, which it too large to upload here, is available at the bottom of this page.
                            • F Offline
                              fbartels
                              This one turned out looking quite glassy. Kinda cool. Some of you in Holland may recognize the place in the image that I used for the texture.
                                twharvey
                                [attachment=1:1qnq3rb6]<!-- ia1 -->ex 1.jpg<!-- ia1 -->[/attachment:1qnq3rb6]
                                [attachment=0:1qnq3rb6]<!-- ia0 -->projection example 2 .jpg<!-- ia0 -->[/attachment:1qnq3rb6]
                                Fred,
                                I downloaded your SU file and tried it. I guess I still don't understand what you did.
                                1. How do you apply the texture to the object when it inside the extruded texture image?
                                2. When I extruded the image, the sides of the box were just parallel stripes (as Normal)so that when I tried to paint them on my object (a cylindar) all I got was the same stripes.
                                Thanks in advance,
                                Tom
                                Tom
                                • F Offline
                                  fbartels
                                  Tom,
                                  I made a quick video tutorial which should make this all crystal clear.
                                  It is fairly large and will take a few moments to download.
                                  It is located here.
                                  Fred
                                    Cool video ☀
                                    Are you the cousin of Niki de Saint Phalle? 😉
                                      kwistenbiebel
                                      Indeed, I always loved those statues and fountain of De Saint Phalle over at the Centre Pompidou in Paris.
                                      Are those still there?
                                      • F Offline
                                        fbartels
                                        Pilou,
                                        I think Niki de Saint Phalle would have really liked SketchUp and LOVED SdS and FFD.
                                        There are some interesting videos of her garden in Tuscany here.
                                        I just read through her Wikipedia page. She was quite the character.
                                        Thanks for pointing her out!
                                        Fred
                                          twharvey
                                          @fbartels said:
                                          Tom,
                                          It is located here.
                                          Fred
                                          Fred,
                                          Thanks. I followed your video and got a good result! 👍
                                          Tom
                                          Tom
                                            I am not sure if the big piece is still there, maybe yes 😄
                                            Tinguely +Nikki = joyous mood ☀
                                            http://www.productionmyarts.com/Images/architecture-musees/paris/paris-centre-georges-pompidou-fontaine-detail.jpg
                                            at flickr 😉
                                            • 2 / 2
