    I want this ...
    25 Posts 9 Posters 2.2k Views 9 Watching
    • soloS Offline
      Would love to see how windows task manager reports activity over all those cores. ๐Ÿ˜ฎ
        Imagine a rig like this with SU using multi-cores on Linux (as Lewis "reported" his machine doing it... ๐Ÿ˜ฒ
        • jujuJ Offline
          juju
          Bugger work, the big question is ... How does it run Crysis?! ๐Ÿ‘ฟ
            remus
            Probably not that well actually, unless you can put in a load of graphics cards. Im sure it wouldnt have too much trouble with the physics engine though ๐Ÿ˜›
            • StinkieS Offline
              Stinkie
              The big question is, as far as I'm concerned, will this provide me with the kind of processing power for the doomsday device I've been working on?
              muhahaha!
                remus
                You going to render it?
                  Could it even run Vista maybe? ๐Ÿ˜ฒ
                  • StinkieS Offline
                    Stinkie
                    lol.
                    • soloS Offline
                      With that many cores, you can just imagine how many 'Apples' it ate. ๐Ÿ’š
                        lewiswadsworth
                        Does it come with a free nuclear power plant to keep the thing running? Otherwise I'm sure it almost immediately brings the local grid down.
                        col sporcar si trova
                          remus
                          apparently it will run on a normal office supply. Probably wouldnt want to hook too many up on an extension lead though...
                            remus
                            I tihnk ive found something to trump that machine: http://www.linuxjournal.com/article/6783
                            Kind of cheating a bit ๐Ÿ˜›
                              lewiswadsworth
                              This guy built a 24 core, 48 GB render farm in an Ikea cabinet for seemingly next to nothing, and he's planning on building a 96 core version. No indication what actually he is using as rendering software, but who cares?
                              http://helmer.sfe.se/
                              He gives fairly detailed descriptions of the assembly...and none of this looks particularly difficult.
                                remus
                                That looks like good fun, a beast as well.
                                As for the software, i iamgine it would be pretty simple with an unbiased render engine like maxwell or indigo, as you could jsut set each of the motherboards up as a slave and render like that.
                                Not sure where you could fins 6 quad cores very cheaply though, i thought the going rate was about 100 quid ๐Ÿ˜• even assuming you got them half price your still looking at 300 quid for the CPUs alone. But then thats a render farm for you ๐Ÿ˜‰
                                • I Offline
                                  igor
                                  well, im still sticking with alienware's octuple core monster with 4 terabytes of memory.
                                  and yes juju, it will run crysis, very very well.
                                  The genius switch has no "off" position
                                  Intelegence is natrual, it takes real effort to be ignorant
                                    dudekracked
                                    guys, ive found something more powerful called fastra
                                    http://www.engadget.com/2008/05/29/researchers-create-supercomputer-with-four-geforce-9800-gx2-card/
                                      remus
                                      Good find, its a pity there arent really many render engines that run on GPU power, youd be sorted otherwise!
                                      Not to mention that fac that you could play crysis on a cinema screen on 'very high' settings ๐Ÿ˜†
                                        lewiswadsworth
                                        I was at an IKEA today and was very tempted to buy a Helmer...
