    Lighting Plugin for Sketchup
    232 Posts 67 Posters 59.0k Views 67 Watching
    • AdamBA Offline
      AdamB
      Adam: SU5 doesn't have WebDialogs
      Ah, ok sounds like you're out of luck, spadestick. I'll be watching closely to see if there is any demand for this though.
      Adam
        spadestick
        thanks guys!
        • mariochaM Offline
          mariocha
          This looks very promising Adam !!
          What is the maximum face number in the present demo?
          %(#008000)[Mario C.
          • AdamBA Offline
            AdamB
            Hey thanks!
            There isn't a hard limit in the demo. However, the demo has some crash bugs in it (now fixed internally), some incomplete features (eg support for Groups and Components which is now fixed internally) and more importantly used some Ruby methods to extract geometry information which is very slow.
            It is this latter issue which means for larger models you have to wait an inordinate amount of time. We know how to fix this and it will be for the next released version.
            Short answer is LightUp is aimed at large models.
            Adam
            • I Offline
              ilay7k
              Great!
              will be resolve feature for user with limited rights(non-admins...for windows)?
              Ilya aka spirekin at your forum
              • jujuJ Offline
                juju
                ^^ Brings tears to my eyes...
                If only SU would handle large models better... (nudge-nudge, wink-wink GSU developers)
                • AdamBA Offline
                  AdamB
                  @ilay7k said:
                  Great!
                  Yes saw your post. I'm a bit unclear what the problem is here because LightUp isn't doing anything that requires special permissions. Its just some Ruby and some C++ running as a plug-in to Sketchup.
                  Any more info you can provide would be really appreciated. And I'll try and get a repro here.
                  Thanks.
                  • EdsonE Offline
                    Edson
                    what happened to the lightup forum? even logged in i cannot seem to find it?
                    http://www.mahfuz.arq.br
                    • mariochaM Offline
                      mariocha
                      I did some tests.
                      To get rid of the psychedelic effect, I had to either explode groups, or make sure there are no groups in groups or modify the group, like add a line in the group.
                      Adding a line at universal level did not correct the problem with the group.
                      Also, (to contribute);
                      There is light behind the feet where there shoud not. The dog looks above the platform.
                      Some faces of the "dog" are somewhat transparent; see the corner of the platform that should be hidden, for instance.
                      And edges appear somewhat chunkier then model really is. (maybe because of the unwanted transparancy)
                      The test model has 2 groups, the dog and the platform
                      The transparent effect is gone if I explode the group.
                      %(#008000)[Mario C.
                      • mariochaM Offline
                        mariocha
                        Well, I guess, this SCF is it now.
                        %(#008000)[Mario C.
                        • EdsonE Offline
                          Edson
                          of course. what i meant is the forum inside the lightup site. was not there one?
                          • I Offline
                            ilay7k
                            as http://light-up.co.uk/forum/index.php ... works well
                            when someone sits on my work-place, I do to create 2 profiles(ohh...there were problems with mutanteded virus-bodies at flash-drives) and sometimes forget to switch to admin...so at "guest" i have always shutdowns of sketch...only when i try to start light simulation
                            all ruby-scripts work fine...
                            • AdamBA Offline
                              AdamB
                              @mariocha said:
                              I did some tests.
                              This is called "bleeding". Its because the platform continues under the feet of the dog so the interpolation incorrectly continues underneath too. You can fix it by changing the model to not go under the feet, also you can reduce it by increasing the Resolution of the lighting. I may add some code to LightUp to try and reduce the artefacts when it detects this.
                              Yes, the demo has a few bugs related to groups/components. Probably simplest to avoid using them for now by exploding the model.
                              Adam
                              • mariochaM Offline
                                mariocha
                                ... that is a LightUp component called an Irradiance Cache. It is discussed in the getting started document.
                                Adam
                                In my humble opinion, the Getting started document would be much more easier to view as a seperate PDF file.
                                It would much less intefere with the flow of work.
                                %(#008000)[Mario C.
                                • AdamBA Offline
                                  AdamB
                                  Edson, the LightUp website has a forum at http://www.light-up.co.uk/forum. Until we get the full version of LightUp out, I've not been able to devote as much time as I would like to it. But please feel free to post questions etc.
                                  [And I haven't forgotten your request for a video showing exterior rendering in LightUp! πŸ˜„]
                                  Adam
                                  • AdamBA Offline
                                    AdamB
                                    Adam
                                    Interesting and noted. Thankyou.
                                    BTW If you want the pdf it lives on Windows at:
                                    /Program Files/Google/Google SketchUp 6/Tools/lightup/GettingStarted.pdf
                                    and on Mac OSX at:
                                    /Library/Application Support/Google Sketchup 6/Sketchup/tools/lightup/GettingStarted.pdf
                                    • mariochaM Offline
                                      mariocha
                                      GREAT ! !
                                      %(#008000)[Mario C.
                                      • mariochaM Offline
                                        mariocha
                                        I have posted a video on youtube. LightUp-Bar
                                        http://www.youtube.com/watch?v=H2m_6hjWUsY
                                        A test. It raised many questions.
                                        One not resolved is why the sofa won't render properly. That checkered effect is wrong, the dark areas should not be.
                                        %(#008000)[Mario C.
                                          swinburne
                                          Hi Adam,
                                          I have loaded the program into pc, all going ok until I click on the tour tool - everything closes down? I'm on SU Pro. Is there anyway I can use this software?
                                          • I Offline
                                            ilay7k
                                            after playing with 3dvia shape(Thanks to Chris and Daniel for link and new gui of 7skipy πŸ˜‰))
                                            can you add support of dds-shader(Or something like symbiont from darksim) to lightUp for realistic materials? ...it's not so necessary but...i know that Pixero has some examples, i have
                                            • 11
                                            • 12
                                            • 3 / 12
