💡 LightUp 7.1 | SketchUp's only real-time renderer that uses object-based rendering
Download Trial
[Plugin] Rectangle Elevated
hallo friend! i am a Italian SketchUp user.
In the script Rectangle is possible edit the code, for to eleve the rectangle?? whit a windows as esample picture??
Thanks!!!PS: excuse my all for my bad Englesh...
the script -
You mean give the 4 corners an elevation other than 0 ?
or pushpull it to get a parallelepipedic solid ? -
@didier bur said:
Man, you're lazy
Try this one (it appears in the Draw menu).
Cheers,thaaaaaaaanks!!!
Didier Bur whit this script i can to build the floor and the wall of autocad file imported quickly
Didier Bur this is for you!
