    [Plugin] SU2POV for GSU6
    49 Posts 10 Posters 37.0k Views 10 Watching
    • I
      ilay7k
      thank you for update!
      Keep it simple!
      it's simple 5-min test work with all Finish mats(with photoshop)
      used 2bounce-settings(1 picture...phong matt) and skylight-settings(for 3 pics,... glass, glossy) and without photon-mapping ๐Ÿ˜ž (a few dark places)...then layer post-processing in pshp
      Please look at export mat like Phong Matt....i used 3.6 pov-ray
      • Didier BurD
        Didier Bur
        Small bug fix this morning, thanx to ilay7k.
        DB
        • I
          ilay7k
          Thanks for update
          esc-pushing error(for placing lights) was fixed by Didier in latest...
          John feel free for download it...
          Can somebody tell about megapov?
          • JClementsJ
            JClements
            I thought I did as I downloaded yesterday. Perhaps a bad link exists. That's the benefit of having the version level listed in the menu. ๐Ÿ˜„
            • JClementsJ
              JClements
              Hi Didier, a brief follow up.
              I haven't had a chance to try the new options except the render with Alpha Channel and I do like that a LOT; I still can't believe that SU isn't capable of doing this natively with their PNG expoxt filter.
              What I can tell you is that the two light tools do work for me ONLY IF:
              1. I import each of their two respective .Skps FIRST so they are registered in the model's component library.
              2. Then, after selecting a tool from your menu, pressing ESC. This allows the scripts to respond to subsequent mouse clicks.
              I am not sure if #1 is related to what the user's default component directory is or not or if it has to do with SU's installed location (mine is C:\programs\SketchUp 6...) .
              Could you include the script's version number in the end of the script name listed in the Plugins' Menu? That would help identify if the latest version has been installed.
              Hopefully, I can be more deligent this weekend and re-try all the settings of your lastest release.
              Regards, John
              • Didier BurD
                Didier Bur
                Hi John,
                All this is fixed now. The compos are loaded from a path relative to the Plugins folder, which Ruby can find by itself. So no matter where your SU main folder is, it MUST load components if they are not already present in the model. I've tested it hundreds of times believe me...
                BTW good idea to put the version number in the menu ๐Ÿ˜‰
                DB
                • JClementsJ
                  JClements
                  I tried downloading again and I see no difference in the light tools and no version level in menu description so I can't verify if I am downloading the wrong version.
                  Can you post the zip here ... at least temporarily until Monday?
                  • Didier BurD
                    Didier Bur
                    Here it is:
                    Replace old su2pov3.rb in your Plugins folder. (it just adds the version number in the menu)
                    DB
                    • I
                      ilay7k
                      John put time-slider in the right end at shadow-toolbar and export with lights
                      and some explanation in POV sample scenes and help-system too...
                      Strange, i haven't esc-effect...
                      ![my "crappy" light-test(skp-balcony scene)](/uploads/imported_attachments/tCIb_testl.jpg "my "crappy" light-test(skp-balcony scene)")
                      • JClementsJ
                        JClements
                        Didier, thanks for posting the .Rb.
                        The component lights are now being found, I no longer have to manually import them prior to using the script,and the version level is displayed.
                        I still have to press the ESCAPE key to initiate creating the lights with mouse clicks, however.
                        Questions (of course :} ๐Ÿ˜ž
                        **1-**In your documentaton you mention that the Sun is automatically "shut off" at night. I had assumed that was when the model was Set to Use Sun for Shading, but this happens as well when it is not set for Use Sun for Shading and also when the rendering setting of Lights is set for lights only. Is this what you intended?
                        **2-**I was curious what the default is for when the script is turned to night mode. Is it a prescribed amount of minutes before the sunset time listed in the Shadows Dialog?
                        **3-**In your documentation you show the Sun actually being rendered in the sky. How is this done, is it automatically placed (per SU's sun position) once the script is run the first time for a model?
                        • Didier BurD
                          Didier Bur
                          Hi John,
                          I never noticed any difference with that checkbox ticked or not. Here is what the SU help says: "Click on the Use Sun for shading checkbox to shade the faces of your model based on the position of the sun. SketchUp uses standard shading that follows the camera when Use Sun for Shading is not enabled."
                          Not correct, at least by me: no standard shading that follows the camera. It makes no difference, that's why the script doesn't take care of it...
                          Almost. The script calculates the "slope" of the sun rays and when it is less or equal than 0 radians it considers that it is night time (sun rays slope is negative during the night because the sun is "behind" the ground). Between 0 and 0.2 radians the color of the sun light is slightly modified (at sunset or sunrise).
                          This is done this way: the script evaluates the angle between camera direction and sun rays vector, and calculates wether the sun is in the field of view or not. When it is, the component "su2pov_sun" is inserted at the right place, then removed after the export is finished. The component uses a png image that goes from white to transparent to mix the sun with the sky color.
                          Regards,
                          DB
                          • JClementsJ
                            JClements
                            Thanks, Didier, for the feedback.
                            "..When it is, the component "su2pov_sun" is inserted at the right place, then removed after the export is finished. .."
                            Very clever programming.
                            Regards, John
                            • jujuJ
                              juju
                              Regards, John
                              +1!
                                sparc
                                Great plugin. Question. How does the plug in know what surface is glass for glass finish?
                                • Didier BurD
                                  Didier Bur
                                  If opacity is less than 100% the scripts considers this is a transparent material and applies a glass finish, if it is set in the rendering options.
                                  PS: i'll publish a 3.2. release soon with a basic material editor.
                                  DB
                                    r_persater
                                    Hi Didier!
                                    I have unzipped su2pov3 and installed su2pov_24_setup.exe. I've also been able to export to POV-Ray and I'm a happy user of that part already now. But installing the 2.4 version gave me the su2pov buttons also. My problem is that I get an error message using the buttons. The program can't find the components (su2pov_spotlights.skp, su2pov_tree.skp etc.) and I can't find them in the installation or in any zip file. Where do I find them? Or should they be in the 3.2 package but happen to be missing?
                                    Another question: Is there a function for making a component a "piece of glass", i.e. give all its faces an interior definition with a IOR? Right now I'm doing it the hard way, pasting a "stolen" interior definition and references into the pov file, but there must be a simpler way...
                                    Thanks for a great job!
                                    /Rickard
                                    • Didier BurD
                                      Didier Bur
                                      Release 3.2 and relase 2.4 are different, you guess. DON'T install 2.4 AFTER 3.2 !!!
                                      DB
                                        r_persater
                                        Hi again,
                                        Yep, I do understand basic version numbers... But installing just the 3.2 version did NOT give me the buttons and component folders, so I tried installing the 2.4 anyway (even if it is an older version). So my question is: Is something missing in the 3.2 installer when I can't find the button toolbars and components? Or is the file su2pov_materials.exe supposed to install them? The problem is I get the following error message trying to run it:
                                        Line -1:
                                        Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded.
                                        Regards,
                                        Rickard
                                        • Didier BurD
                                          Didier Bur
                                          There are no toolbars and no icons in 3.2. Maybe in 3.3 ๐Ÿ˜’
                                          su2pov_materials.exe is an executable that runs from within SU when you edit pov-ray material properties.
                                          Regards,
                                          DB
                                            r_persater
                                            OK, that explains why... ๐Ÿ˜
                                            Is it possible to get the 2.4 versions lights, 3D trees etc. somewhere? Or is a 3.3 version coming soon? ๐Ÿ˜‰
                                            • 2 / 3
