    Gallery Hall (Vray Render)
    13 Posts 7 Posters 1.5k Views 7 Watching
      Khshahen
      Hi all,
      Here is another model rendered with vray. Hope you guys like it.
      cheers,
      Khalid
      β€œEvery act of creation is first of all an act of destruction.”
      • FrederikF Offline
        Frederik
        Great work...!! πŸ‘
        And the textures are very well done... 😎
        I like the soft appearance in the render... How did you achieve it..??
        Cheers
        Kim Frederik
          Khshahen
          Thanks Frederik for the comment. In this scene I used three different types of lighting. Omni directional light from outside, vray emissive light from the ceiling) with value 1, and an inside rectangle light with the value set to 2. That's it.
          Cheers,
          Khalid
          • DanielD Offline
            Daniel
            Nice rendering. Would that soffit light be clad with stone (how would you support it?)? If so, wouldn't you see the thickness of the stone on the underside?
            My avatar is an anachronism.
              mateo soletic
              Tray emhasising those paintins with some light, other than that nice work.
              Concept Illustrations
                ScottPara
                I would imagine it is only face stone attached much like wall tile.
                Scott
                Love the fact that some HATE my avatar.....
                  Khshahen
                  It's a wall tile and the X and Y set to 1 meter.
                    Khshahen
                    Dear Daniel, honestly I didn't get your point.
                    • AnssiA Offline
                      Anssi
                      Don't cover the paintings with the lighting fixtures. Better use spotlights fixed to the ceiling.
                      Anssi
                        cheffey
                        He's referring to the linear light or lightwell just above the paintings.. it looks like the face of that is clad with stone like the wall. if so, you will need a lintel of some type.
                        if this is just for kicks then no harm, just the architects will notice such things.
                        BROS RŌMAN BRΓ„UN
                        • DanielD Offline
                          Daniel
                          Sorry, I'm being excruciatingly picky - has to do with my job this week. It appears to me that you applied the stone material to the font face only of your soffit light (as illustrated on the left, below), but didn't return it on the bottom to show the thickness of that stone (as shown on the right, along with a supporting frame). It's the sorta thing that only an architect would probably notice.
                          • DanielD Offline
                            Daniel
                            [attachment=0:1utuuevu]<!-- ia0 -->stonesoffit.jpg<!-- ia0 -->[/attachment:1utuuevu]
                            regardless, it's a nice rendering.
                              Khshahen
                              @daniel said:
                              [attachment=0:247hl1ac]<!-- ia0 -->stonesoffit.jpg<!-- ia0 -->[/attachment:247hl1ac]
                              not at all Daniel, you're most welcome. Now I got your point. The most difficult part in any realistic rendering is the light distribution and the texture mapping technique. This model took me more than 2 hrs to achieve such an output. Currently, i'm experimenting fluid and realistic water surface which is really hard to achieve in sketchup+vray. The minutes it's done I'll post it here and your comments will be a plus.
                              Cheers
                              Khalid
