    WebDialog Closes Mysteriously
    11 Posts 4 Posters 989 Views 4 Watching
      Jim
      Can anyone think of a reason my dialog would just close on its own?
      I'm uploading a video, but all I am doing is moving the mouse around and it closes.
      Here's the video. You can see it closes immediately the first time.
      http://video.google.com/videoplay?docid=1449501159821628686&hl=en
      Here's the "offending" code.
      require "sketchup"
      def create_dialog
        dlg = UI;;WebDialog.new("Jitter", false, "Jitter2", 100, 100, 100, 100, true)
        dlg.set_file( File.join( File.dirname(__FILE__),  "ui.html" ))
        dlg.show {}
      name = "jitter.rb"
      unless file_loaded? name
        UI.menu("Plugins").add_item("Jitter Vertices") { create_dialog }
        file_loaded name
      <html>
        <body>
          <fieldset>
            <legend>Jitter</legend>
            <input type="text" id="jitter_amount" size="5">
            <button>Jitter</button>
          </fieldset>
        </body>
      </html>
        Jim
        I had to clear out my Plugins folder, but the problem went away.
        I'll post if I find anything.
        • W Offline
          Whaat
          I had this problem until I made my web dialog objects global.
          • AdamBA Offline
            AdamB
            I could totally believe thats the problem. ie Ruby (correctly) garbage collects when it goes out of scope.
              Jim
              Yes, but the problem goes away if I clear the Plugins folder, and load only this code.
              I don't understand how the scope is the reason. If that were so, wouldn't many other plugins go out of scope and not work?
              • tbdT Offline
                tbd
                name clashing? search for other plugins with create_dialog, dlg.
                maybe there is a conflict somewhere.
                or you can add plugin by plugin and see the offending one
                http://plugins.ro
                  Jim
                  Thanks for the comments.
                  I replaced all occurrences of "jitter" with "shake", but it still happens. I recursively grep'd through the Plugins folder for "shake", and mine is the only occurrence.
                  My latest custom toolbars plugin is one that causes the problem. However, it can't be Whaat's problem because no one else has this plugin yet. My toolbars plugin reads a text file, loads a file, and creates Toolbar objects.
                  Here's an example "command" file:
                  cmd = UI;;Command.new("Arc") { Sketchup.send_action "selectArcTool;" }
                  cmd.large_icon = "../images/arc_lg.png"
                  cmd.small_icon = "../images/arc_sm.png"
                  cmd.tooltip = "Arc"
                  cmd.status_bar_text = "Draw arcs"
                  cmd.menu_text = "Arc"
                  cmd.set_validation_proc { tool_validation_proc("ArcTool") }
                  @cmd = cmd
                  and here's a simpified example of how I am loading it:
                  ruby_files.each do |file|
                    load file
                    toolbar.add_item @cmd
                  See any problems here? The plugin is not ready for the public, but I can share it if anyone wants to have a look for any problems.
                  • tbdT Offline
                    tbd
                    Jim: I can take a look, if you want, and see if it shows the same behaviour here
                    http://plugins.ro
                      Jim
                      I've sent the plugin in a PM, thank you.
                      • AdamBA Offline
                        AdamB
                        Sure, but in doing so you're changing the character of garbage collection.
                        My hunch (based on nothing) is that the schema handler stuff (ie skp:blah) just expects the dialog to stay in scope although its an asynchronous process. Your code exits the block and does other stuff, 256 opcodes later (yes, I saw it in the Ruby source code - ouch!) the GC kicks in and sweeps it away. The javascript side then gets its knickers in a twist because the Ruby side dialog that was consuming data has disappeared.
                        Adam
                          Jim
                          Thanks for the comments, everyone; and especially to TBD.
                          It seems obvious now, but the variable that is referencing the dialog is local to the method. When the method is finished, so is everything else in the same scope. And so sooner or later the variable will get cleaned up by Ruby's garbage collection, and the dialog "mysteriously" goes away. So for the code I posted, a global variable will solve the problem. You could also use an instance variable.
                          Please, correct any mis-understandings I have about what's happening.
