[Plugin][$] VisuHole - v1.5a - 01 Apr 24
I know it, I have uploaded the new Spanish Language for LibFredo6 v6.1a but these are missing strings to translate in VisuHole:
• "Current Stencil" • "Next Stencil in History" • "Previous Stencil in History" • "Pick a Stencil Shape in the Model" • "PICK A STENCIL SHAPE" • "Pick a Stencil Shape - Click / Release to pick or Click / Drag / Release to pick and orientate - Ctrl down to Force faces - Esc to cancel"
Oxer,
There seems to be a small problem, maybe for because of the '/'.
Still I was able to translate these strings to French. So I need to clarify.
Fred
Thanks for the reply!
Awesome, I will try as soon as I can.
Quick question before downloading it: saw the first minutes of the tutorial video... when moving the stencil shape over the surface you want to apply the stencil, it seems the stencil is "grabbed" by it´s middle.
Is it possible however to for example, move a stencil by it´s corner, and then position it precisely somewhere?
Yes of course!
When you select a new stencil you choose its own origin and even its orientation!
And when you draw it on the volume again position and orientation (on the volume) are possible!
A must indeed! -
Is it possible to get the result in the back (one step) if you place the drill shape at a border?
[attachment=0:6kxwbix7]<!-- ia0 -->drill_border.jpg<!-- ia0 -->[/attachment:6kxwbix7]
Just make the rectangle a little bit higher. With exact dimensions, VisuHole has difficulty because it does know the original border faces stay.
Is it possible to snap the stencil shape (drill thru) to guide points, guide lines? Or to use the normal inference system for positioning the hole?
You can yet with this little trick and if your face volume is Parallel to one axe!
Draw your guides lines crossing anywhere you want
Then call the Stencil and Press one of the the Keyboard Arrow (so x, y, z axis)
The snap will be fine on the crossing guides lines!Curiously don't work with a Guide Point on the surface but Yes if the Guide Point is on the empty space!
So put the Guide Point on Guideline(s) who will be itself on the surface volume!
Edit : seems you cant draw your stencil on any position on the space of one Guide Line!
So no need to press the Arrows'keys!
But not on their intersection! Even Drawn a Point Guide at the intersection first!
All must be on the surface of the volume!
Guide line(s) + Point Guide -
WWWWWWWonderful script indeed!
Fantastic plugin! (as usual) Thank you very much!
We have yet the rotation
but...
... does this is possible ?
Will be very smart!
And a Gizmo with separated scale X, Y, Z super smart!
Congrats Fredo! Another great release! I am looking forward to playing with this one...
Fredo this looks amazing! I can 't wait to play with this one!
NEW RELEASE: VisuHole v1.1a - 19 Oct 14
VisuHole 1.1a is required for the support of usernames with non-ascii characters in Sketchup 2014
See main post of this thread for Download of VisuHole.
Once more time, awsome tools.
MALAISE
This is an awesome plug-in, thank you! I have one question, if for example I punch a hole in a component it seems to make that component unique and doesnt make that change to what were instances of the original component. It cant see to find if there was an option to make the change to all instances of the component. Other "typical" changes on components are working properly. Am I doing something wrong? Or have some preference set wrong?
Thanks again!!
Thanks again!!
You have the choice
If you are outside the component, only the component selected is affected (and thus is made unique)
if you are inside the component, then all instances will be affected.
Just found this...awesome indeed. Any tips on how to position the drill on guide points or lines? The stencil seems to disappear when I hover over a guide cross or guideline that intersects a face. I would love to know how to accurately place the drill. Very cool. I'm using SU15.
