Extension Creator
Share, test and sell extensions
RE: Parametric Modeling - development?
@Jorgensen said in Parametric Modeling - development?:
I've been jealous of the users of Rhino for some years - that they have the node based tool - grasshopper.
I think node based modeling could be a big think for Sketchup, but it seems development stopped back in 2021, witch I find sad....
Sorry, Cannot help with contact.
But SketchUp Live Components and the Trimble Creator have not been abandoned AFAIK.
Discussion is still happening in its SketchUp Labs subcatgeory.
[Plugin] Dialog Cascader - recover and collect Ruby dialogs
[Extension] Dialog Cascader for Ruby extension dialogs
v 1.0.0
Purpose: Brings together extension dialogs scattered on multiple screens or possibly lost offscreen. May be a benefit to users with notebook docks or who move their machine between locations with differing display setups.
Will not work on native web-based dialogs such as 3D Warehouse, Extension Manager, etc. (These windows are hidden from the API.)
NOTE: SketchUp 2024 has had some fixes that can natively detect lost dialogs and move them back onto an active display. This extension is meant for older versions that do not have this fix or possibly as a complement for when the native fix might fail.
Localized for SketchUp supported languages (and nl & uk.)
Adds a menu item to the Window menu.
Provides a toolbar with a button:
- single-click: cascades any open Ruby dialogs
- double-click: shows About dialog
Tested on MS Windows platform. Version 2024, 2023, 2022, 2021, & 2017.
I tried to write this so it might possibly even load under Ruby 1.8 for versions prior to SU2014.
But no guarantees for such old versions. (I do not have a machine ready that can run these old versions and I'm not really interested in trying to test for them.) -
RE: Medeek Wall Plugin
Version 3.6.5 - 06.12.2024
- Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
RE: plugins
When you buy a Fredo6 license it allows you to install it [and validate it] on up to 3 different computers.
You simply copy the license file onto the other computer and use that file to activate a license for the related extension on that computer.
There are also tools available on the SketchUcation website to manage licenses later on - e.g. if you get a different computer that needs a license, and you can remove a validation from the previous computer.Cuando compras una licencia de Fredo6, te permite instalarla [y validarla] en hasta 3 computadoras diferentes.
Simplemente copie el archivo de licencia en la otra computadora y use ese archivo para activar una licencia para la extensión relacionada en esa computadora.
También hay herramientas disponibles en el sitio web de SketchUcation para gestionar licencias más adelante, p. si obtiene una computadora diferente que necesita una licencia, puede eliminar una validación de la computadora anterior. -
RE: [Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
Just in case could you open the Default Parameters dialog and uncheck or check this option
RE: LOTT POSITION
Can you go to the Default Parameters dialog and uncheck the option
RE: SCFLicense: Extension Licensing on Sketchucation
I assume you have saved your license files to some subfolder on your computer - e.g. ../Documents/Licenses
That's not sufficient to complete the action.
It is spelled out in the help links above...
Stat SketchUp and under the Tools menu find the Fredo6 Collection item, look for your extensions.
Find the section about License...
In the dialog choose 'Activate License' and find the license file on your computer...
Your screenshot shows you are almost there...
You need to be connected to the Internet to do this.
Click the Activate License button and navigate to your license file saved onto your computer.Note that FredoCorner and RoundCorner are different extensions and need to have their own license on your computer and Activated...
Occasionally users confuse the two extensions and do not actually have a valid license file available... -
Have you downloaded/installed the latest versions of all of those bundled Fredo6 extensions, and LibFredo6 and the SketchUcation tools [for the latest licensing set up].
You also need to restart SketchUp to sync everything.The license files you got for the bundled set need to be stored somewhere safe on your computer - e.g. in a special subfolder made in your Documents folder. You then need to 'validate' each of them individually for each of Fredo6's extensions in the appropriate submenus under the Tools menu.
