    Photoshop Dialogue Boxes
    6 Posts 3 Posters 784 Views 3 Watching
      Bernard Hagan
      I'm having a great deal of difficulty trying to get Photoshop's dialogue boxes to appear on screen so I can enter data or adjust sliders.
      I think the problem arises because I am on holiday away from my usual dual 17" monitor setup and have to use a single 15" monitor instead.
      When I try to - say, change the size of the canvas of the image I'm working on - the dialogue box where I input the dimensions I want appears off screen so I cannot see it. It also locks most of the menus so that the only way to proceed is to close down Photoshop using the Task Manager and start again.
      I have made sure the Display Properties>Settings>Advanced [Windows XP Pro] are set to using a single monitor of lower resolution and refresh rate and everything else seems to work fine - except for Photoshop [6.0].
      I have tried to find some way of centering the dialogues on the Net without and success.
      Any ideas?
      Bernard
      Our fantasies keep us safe and sane in an incomprehensible, indifferent universe: inevitably we comprehend them as reality itself.
      • tbdT Offline
        tbd
        does the trick ALT+Space(gives the system menu), M(ove) then left/right on keyboard and moving the mouse works ? (try it first on a normal window, e.g. Explorer)
        if not reset the preferences as explained here
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          Bernard Hagan
          TBD - Your 'trick' using Alt+Space>M[ove]>direction arrows, works just fine. You have saved me heaps of frustration and wasted [holiday] time. Is this a Windows or a Photoshop 'trick'? Are there any others?
          Thank you very, very much.
          Bernard
          • tbdT Offline
            tbd
            here are some
            I use mostly Win Logo key combinations and HoeKey/WinKey program to build my own combos (Win+S - Start SketchUp)
            http://plugins.ro
              Bernard Hagan
              Very Interesting . . . .
              Thanks again TBD
              Bernard
              • Didier BurD Offline
                Didier Bur
                I've had this problem too, many times, since I got a 24" screen.
                I didn't know the trick "Alt+Space>M[ove]>direction arrows", the only solution I've found then was to delete the Adobe PhotoShop config files. They are in C:/Documents and settings/your_user_name/Application Data/Adobe/Photoshop/your_ps_version/Adobe Photoshop Settings.
                When you re-start PS, everything is re-initialized and every dialog box stands at the center of the screen (but you've lost your customization too 😞 )
                DB
