    Move! bug?
    1 Posts 1 Posters 652 Views 1 Watching
    • J
      Jim
      Does everyone know this but me... 😳
      First, the API docs for the Group.move! method:
      move!
      This method is the same as the transform! method except that it does not record the move in an undo operation. This method is useful for transparently moving things during an animation.
      This code tells a different story. It seems that grp2 is moved to an absolute position even if a Vector is used for the Transformation object. My expectation is that both groups would be moved 3 times, leaving a trail of numbers.
      require "sketchup.rb"
      puts Time.now
      grp1 = Sketchup.active_model.selection[0]
      grp2 = Sketchup.active_model.selection[1]
      v1 = Geom;;Vector3d.new(X_AXIS)
      v2 = Geom;;Vector3d.new(X_AXIS)
      v1.length = grp1.bounds.width * 2
      v2.length = grp2.bounds.width * 2
      tr1 = Geom;;Transformation.new(v1)
      tr2 = Geom;;Transformation.new(v2)
      3.times do |i|
         grp1.transform! tr1
         grp2.move! tr2
         Sketchup.active_model.entities.add_text "g1-#{i+1}", grp1.transformation.origin
         Sketchup.active_model.entities.add_text "g2-#{i+1}", grp2.transformation.origin
