    Is there an "Undo" script?
    3 Posts 2 Posters 908 Views 2 Watching
      Baker518
      I may be imagining this but I thought I saw a RS that would let you UNDO many times more than what is standard? I saw one that would let you back up several views, but not an actual Undo.
      Don't worry about things you have no control over. Worry is a lack of Faith!
        azuby
        Some months ago I started a project called "Model History" I should go on developing 😉 The plugin lets you set (and so on ...) the actual status of your model and saves your model file for later usage. It's more a kind of version control plugin Have a look here. (I think, this isn't what your looking for)
        azuby
          Baker518
          Your right, I dont think thats what I had in mind. There are times that I draw something only to find that the geometry is wrong when I change the view. So rather than scrap the piece all together, I start "undoing" what I did and backing out of the errors till I get back to where I can start again. There are only so many times that Undo will work, and yes, you think I would catch it before it gets that far, lol.
          Thats why I was thinking I saw an Undo script that would back up many times.
          Thanks for the response
          Mike
