    Look around tool in ruby?
    8 Posts 3 Posters 1.6k Views 3 Watching
    • PixeroP Offline
      Pixero
      How does the look around tool work in ruby?
      The rotate view rotates around a target point
      but the look around tool rotates around the position of the "camera".
      How is that done in ruby?
        todd burch
        With Camera.direction and Camera.up.
        Todd
        • PixeroP Offline
          Pixero
          I tried that and also "camera.set eye, target, up" but can't get camera to rotate.
          What's the right syntax? Is there a "camera.set eye, direction, up" ?
            todd burch
            I should have said "with camera.set by changing the direction and tilt", but I think you understood.
            You say "why doesn't my code work, because I am doing that".
            Now, I have to say, I need to see your code to tell you why your code does not work, intead of trying to guess what you are doing wrong. There are a couple ways to approach this. It's too brain-racking to try and guess.
            Todd
            • PixeroP Offline
              Pixero
              Here is some testcode I use.
              I get: <ArgumentError: Eye, Target and Up are required> when using camera.set direction
              I also tried with: direction.set!(@rx, @ry, @rz); but nothing...
              # Testing code
              # Name; 	jsCameraTool
              # Author; 	Jan Sandstrom   www.pixero.com
              # Description; 	Position and rotate the camera numericly.
              require 'sketchup.rb'
              def jsCameraTool
              model = Sketchup.active_model
              view = model.active_view
              camera = view.camera
              eye = camera.eye
              direction = camera.direction
              target = camera.target
              up = camera.up
              length = camera.focal_length
              fov = camera.fov
              ### Dialog
              	@px = eye.x
              	@py = eye.y
              	@pz = eye.z
              	@rx = direction.x
              	@ry = direction.y
              	@rz = direction.z
              	#@tx = target.x
              	#@ty = target.y
              	#@tz = target.z
              	prompts = ["Position X", "Position Y", "Position Z", "Rotation X", "Rotation Y", "Rotation Z"]
              	values = [@px, @py, @pz, @rx, @ry, @rz]
                  	results = inputbox(prompts, values, "JS CameraTool")
                 	px, py, pz, rx, ry, rz = results
                  	@px, @py, @pz, @rx, @ry, @rz = px, py, pz, rx, ry, rz
              	# New position
              	camera.eye.x = @px;
              	camera.eye.y = @py;
              	camera.eye.z = @pz;
              	camera.direction.x = @rx;
              	camera.direction.y = @ry;
              	camera.direction.z = @rz;
              	#target.x = @tx;
              	#target.y = @ty;
              	#target.z = @tz;
              	#up.set!(0.0, 0.0, 1.0);
              	#camera.set eye, target, up;
              	camera.set direction;
              end # end of jsCameraTool
              if( not file_loaded?("jsCameraTool.rb") )
                  UI.menu("Plugins").add_item("JS CameraTool") { jsCameraTool }
                Jim
                camera.set takes 3 arguments: the eye (Point3d), the target (Point3d) and the up direction (Vector3d).
                camera.set(eye, target, up)
                • PixeroP Offline
                  Pixero
                  Thats just it.
                  How do I set the camera.direction?
                    Jim
                    You need to use camera.set. The vector from the target to the eye is the direction.
                    m=Sketchup.active_model
                    view=m.active_view
                    camera=view.camera
                    v1 = (camera.target - camera.eye).normalize
                    v2 = camera.direction.normalize
                    p v1 == v2
