    Is disabling menu items and or tools possible?
    7 Posts 2 Posters 2.6k Views 2 Watching
    • M
      Maggy
      I know that it's very easy to add menu items, tool bars, context menu items with Ruby in Sketchup, but I tried to disable/hide/remove and as far as I can see that's not possible.
      Any suggestions?
      [Maggy]
      • A
        azuby
        Remove/Hide: Not on the running process
        Grey=Disable: Depends on the script
        azuby
        • M
          Maggy
          Thanks.
          Grey sounds good enough. But the only grey I can find is in the class Color document.
          Can you tell me where to find more information?
          [Maggy]
          • A
            azuby
            Yes, in the sketchup Ruby API documentation,
            http://download.sketchup.com/sketchuphelp/gsu6_ruby/Docs/Ruby-Menu.html#set_validation_proc
            But the example is a shame. So have a look on these few lines of code:
            grayed_proc = Proc.new { @active_model.path.empty? ? MF_GRAYED ; MF_ENABLED }
            azubymenu = UI.menu("Plugins").add_submenu "Cornflakes"
            azuby_menu_item = azubymenu.add_item "Add milk" do
              UI.messagebox "Adding milk to your cornflakes"
            azubymenu.set_validation_proc azuby_menu_item, &grayed_proc
            # take care for the "&" or write the line;
            azubymenu.set_validation_proc azuby_menu_item do
            An equal usage is possible for toolbar items.
            azuby
            • M
              Maggy
              Why didn't I get Ruby in school, when I was 10 years old or so? Now, 40 years later it's very hard to grasp. The most frustrating part it that it looks so easy when I read a perfectly functioning ruby script. But it looks just as easy in a script that's not doing what I expect it to do...
              I copied your code to "cornflakes.rb", loaded it, it shows up in Plugins, it adds milk to my cornflakes, but I do not see it grey out any menu item. So I started editing, editing, editing, each time closing SU, restarting it, reloading Cornflakes.rb till the milk and cornflakes were coming out of my ears, but still no greyed out menu items.
              [Maggy]
              • A
                azuby
                Maybe because you have to set the @active_model before using the code - like this:
                @active_model = Sketchup.active_model
                I haven't ried the code and at the moment I'm in university and do not have Sketchup installed. I'll care this evening, if it won't work as expected.
                azuby
                • A
                  azuby
                  For me this code works with the additional line. I put it to a .rb file, load Sketchup, try to use Plugins > Cornflakes > Add mild, it is grayed, I open a .skp file and try the same and get my breakfest.
                  azuby
