    Metrics or inches
    6 Posts 4 Posters 1.6k Views 4 Watching
    • M
      Maggy
      I'm trying to use extrude_faces_along_normal.rb. My model is in meters. But when I try to extrude faces 16 meters, it does extrude exactly 16 inches. When I type in 16m instead of 16, nothing happens. I tried again after using a calculator to convert 16 meters to inches, typed in 630 but then the extrusion was much too long, didn't measure. (630 feet? 630 yards?)
      Then I looked into this script, it looks extremely simple but I can't find where it decides wether to use inches, feet, yards, meters or whatever. I dived into "Programming Ruby", couldn't find the answer, searched the ruby forum... I'm lost.
      BTW I do not know who wkai is, the writer of this ruby, but once I get it to work, it'll save me te manual extrusion of 19000 faces! Just in one project. I believe we, ruby downloaders, can't ever thank ruby writers enough for all the time they save us.
      [Maggy]
      • jujuJ
        juju
        True, true. Thx to all the ruby programmers out there, even the ones I pay for scripts... πŸ˜‰
        • Didier BurD
          Didier Bur
          All distances and lengthes are stored in inches in SU. Totally idiot IMHO, but that's the way it is.
          Replace the following line: e.pushpull Float( dist[0])
          with e.pushpull Float( dist[0]).m
          That's it !
          To convert a metric number in inches, for instance 16m, you can type in the Ruby console: 16.m and you'll get 629.92125984252
          Cheers
          DB
          • M
            Maggy
            Thanks a lot!
            It's all over the docs that SU internally only uses inches. But no simple explanation on how to change an imperial script to metrics. A bit strange (read: yes, idiot indeed).
            I guessed, after looking into existing scripts, that .m somewhere should do the trick.
            I probably tried
            e.pushpull Float( dist[0])".m"
            e.pushpull Float( dist[0].m)
            e.pushpull Float( dist[0.m])
            e.pushpull Float( dist.m[0])
            plus several other places in the script.
            And I already found out that in this case e.pushpull 630 gave an acceptable result after all. The first time I tried that I must have accidentally pushpulled a much smaller face than I thought.
            [Maggy]
            • T
              todd burch
              If you want to change the default displayed unit in a model via Ruby, you have to change an Option (See Ruby Help>Classes>OptionManager). They are all stored in a Hash. If you want more help, lemme know.
              Also, you might try typing in "16.meters" (no quotes).
              Todd
              • M
                Maggy
                Thanks Todd, I'll look into it in case I'm going to need it (likely) but Didier already solved it for this script.
                [Maggy]
