    Tubealongpath.rb
    28 Posts 12 Posters 5.3k Views 12 Watching
      stefx
      Hi Gaieus,
      Thnak you very much for your answer.
      I got a problem.
      I get copy and paste in a notepad and then save it with the name "tubealongpath.rb" in the plugin folder (so i can see a txt file with that name) but also after a restart I cannot see anything in the plugin menu...
      have you got any idea about the mistake?
      Thanks.
      Stef.
      • jujuJ Offline
        juju
        What OS are you using and do you have administrative privileges using the logon you're using when you do the changes?
          I think ruby scripts are csae sensitive. Save with the exact name I posted.
            stefx
            Hi Juju,
            I'm using Windows Xp.
            I didn't get any problems with plugins and .rb files before.
            I think it is really weird.
            There are not many things to try......so....
            if someone find out something let me know!
            thanks.
            stef.
              remus
              You could always right click the link in the OP and download the file straight to your plugins folder. That would hopefully eliminate any problems with naming the file.
                stefx
                Hi Remus!
                Thank for your tip!
                I tried it and now it works properly!
                For sure it was my mistake in terms of name....anyway...
                Now I start to play with it...it seems like follow me....is there any chance to have different radius of different section of the same pipe?
                stef.
                  Hi Stef,
                  Not with thisscript. Still it is very handy because it creates the extrusion easily and you need not hassle with aligning faces perpendicular to lines and such.
                    stefx
                    Gaeius,
                    Thank you very much for your help!!
                    the script is very helpful!
                    Very good job!
                    Stef.
                    • 2 / 2
