    Working with selection - ungrouped or within a group
    4 Posts 2 Posters 8.2k Views 2 Watching
    • PixeroP Offline
      Pixero
      (Posted this at the SketchUp forum but since its dissapearing I'd thought I'd post it here also)
      If I want a script to work with a selection of either ungrouped objects or within a group.
      Could something like this work?
      if selection.typename == "Group" { entities=group.entities }
      else { entities=model.active_entities }
      • Didier BurD Offline
        Didier Bur
        No.
        You cannot have a selection of entities in and out a group/component at the same time.
        Shetchup.active_model.active_entities returns the whole model if you aren't editing a group/component, and returns the collection of entities of the group/component if you are editing a group/component.
        Shetchup.active_model.selection is completely different from that.
        Hope this helps,
        DB
        • PixeroP Offline
          Pixero
          I'll try to explain what I'm after.
          Is it possible to make a script work with either the edges/faces in a selected group or the ungrouped edges/faces if there is no group?
          I don't mean at the same time, but to recoginize if the selection is a group or not and be able to work either way.
          If not, I guess I'll have to make two scripts, one for groups and one without.
            Didier Bur
            Yes it is doable.
            For instance:
            def editing_group?
            if Sketchup.active_model.active_entities.parent.class == Sketchup::ComponentDefinition and Sketchup.active_model.active_entities.parent.group?
            return true
            else return false
            Will return a boolean to tell the script if the user is currently editing a group. BUT using methods of the selection class is independant of that.
            Even if the user is editing a group, Sketchup.active_model.entities can be accessed the usual way, and Sketchup.active_model.active_entities will return a collection of entities of the active group/component.
            If you have to check wether selection is a group or not, use this test:
            (because group are stored as if they are components !)
            and if you have to check wether a particular selected object is part of a group or not, use this test:
            if editing_group? and Sketchup.active_model.active_entities.include?( object_id ) ...
            Hope this helps,
            DB
