    Channeling Zaha
    14 Posts 6 Posters 3.4k Views 6 Watching
    • F Offline
      fbartels
      A few images of some funky work I'm doing to limber up for a Hadid style house I'll be attempting next week.
      As this is my first "sharing post" on the new forum I want to say how much I appreciate the supportive but challenging environment that Coen and the moderators have created here with their tremendous care and hard work. Thank you! Thank you! Thank you!
      Now, about that blue color...
      http://dws.editme.com/files/NovDec2007/experiment_2.jpg
      http://dws.editme.com/files/NovDec2007/experiment.jpg
      • tinanneT Offline
        tinanne
        Those are really great! Looking forward to seeing what's next 😄
        Executive Director : American Society of Architectural Illustrators
        AIP 30 Competition opens soon. ASAI.org
        Architectural Rendering
        • F Offline
          fbartels
          The following is much closer to what I'm aiming for. It's a process.
          http://dws.editme.com/files/NovDec2007/zaha 2 small.jpg
          • boofredlayB Offline
            boofredlay
            You have too much fun. These are nice.
            • F Offline
              fbartels
              Tina and Eric. Thanks for your encouraging comments. Much appreciated.
              I've been mulling over how to approach this Zaha house. At first I thought I'd use a facade of curvy panels separated from, but attached to, the house structure. That seemed a little too superficial, so I thought I'd try putting the curves right into the walls. My first test wall, which can be seen below, was a little too ambitious in terms of poly counts and in the process of doing multiple intersects I didn't get everything. Anyway, it was a step forward, and the next test wall should be much better.
              http://dws.editme.com/files/NovDec2007/zaha proto.jpg
              • F Offline
                fbartels
                Getting closer but not there yet. SketchUp gets very funky sometimes when intersecting TINs. I'll try again with fewer polys. Meanwhile, this is the second attempt.
                http://dws.editme.com/files/NovDec2007/zaha 2.jpg
                • F Offline
                  fbartels
                  Used a much bigger grid size on the TINs and everything went smoothly. This is getting pretty close to what I'm aiming for.
                  http://dws.editme.com/files/NovDec2007/zaha 3.jpg
                  • F Offline
                    fbartels
                    I had the morning free today so I put together the walls and the roof. The walls have not yet been cut horizontally with their signature Zaha Hadid curves. That's step 4.
                    The first image shows the walls and roof before cutting with the intersect with model tool. The second image shows the model with all the excess wall areas cut away and the walls fitting nicely under the roof.
                    Should be able to finish this up in another day or two.
                    http://dws.editme.com/files/NovDec2007/zaha 5 pre first cutting.jpg
                    http://dws.editme.com/files/NovDec2007/Everything Put Together.jpg
                    • F Offline
                      fbartels
                      This turned out a little differently than I expected. Anyway, the shell is complete. I don't feel like working on the interior just now. I think the roof would be fun to mow... at least the first few times.
                      Time to go make Apple pies.
                      http://dws.editme.com/files/NovDec2007/Zaha 6 700.jpg
                      http://dws.editme.com/files/NovDec2007/Zaha 6 2 700.jpg
                      http://dws.editme.com/files/NovDec2007/Zaha 6 3 700.jpg
                      http://dws.editme.com/files/NovDec2007/Zaha 6 4 700.jpg
                      • F Offline
                        fbartels
                        is located here http://dws.editme.com/NovDec2007
                          linea
                          We need to build this! I really like that, nice modelling and I like the bulbous walls. It would be interesting to see an alternative where the top of the wall just smoothly flows organically into the roof with a softer overhang, or you could remove the soffit altogether. I've tried to do an example, I haven't done your design justice though, but I did get carried away in Photoshop 😄
                            Ross Macintosh
                            You'll need a goat.
                              bertb
                              nice job, but what do you think about trying something zahadstyle like this?
                              success
                              • F Offline
                                fbartels
                                John,
                                Thanks for your comments. The shaggy roof you created in Photoshop is great! What a delightful surprise to find on the morning forum check.
                                It's clear a house like this would need one of these with its own little curved-roof charging garage.
                                I've put an early version of the model that corresponds to the image below here. The roof could fairly easily be altered to minimize the soffit by moving a few elements, reintersecting, then copying the new roof and using "paste in place" on the newer walls.
                                http://dws.editme.com/files/NovDec2007/Zaha 4 Roof Creator.jpg
