    Select Visible?
    4 Posts 3 Posters 1.2k Views 3 Watching
      Jim
      Is there a plugin to select only geometry that can be seen on the screen?
      Edit: Including the backfaces. Maybe select visible is a bad description. How about select all within the field of view?
      • tbdT Offline
        tbd
        I have written a SelectVisible class but it is a .rbs file (cannot attach here) and available only for private use.
        if you want some tips I am available via email or PM.
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          CPhillips
          Cant you just use select and drag across the whole window? That does the same thing.
            Jim
            Yes, but wanted to do it using Ruby.
