    SketchyPhysics Alpha
    90 Posts 26 Posters 27.1k Views 26 Watching
    • E Offline
      eldar
      hi! i was wondering if there's a way to lock the pose in SketchyPhysics, maybe with an example i can explain myself (english is not my first language) i downloaded the model of the robot arm, open the model, push the play physics button and start to move the fingers and made a cool pose, but when i finish and use others sketchup buttons the pose is lost, my question is: there is a way to not lose this pose or save it, stay with the worked pose and continue working with the tools of sketchup, draw something, etc? (maybe save in a layer?)
      This is very important also in my work as an architect to design solar protection windows and stuff like this. Amazing tool by the way, thanks!!
        Julius
        i don't think so...anyway wait for CPhilips'answer.
          CPhillips
          I understand. That should be possible. Ill add it to my list.
          You could do something similar now if you take advantage of a bug. Just save the model while the simulation is running. It will save it in the posed position.
          Chris
          • E Offline
            eldar
            CPhillips thanks for considering the idea and sorry for my late answer, as you said save the model is the solution, for me this open a lot of new possibities like make a simple skeleton to a design character and pose the figure in contex to make a draw... all inside sketchup instead to learn and buy poser (i know poser is a much more powerfull program but it's only for this then i needed)
            ...one more question is in yours planes to add a feature to make the sketchyphysics an executable? (.exe) something like blender with his gamengine, it will be very cool to have a feature like that, view and walk to the model from a human point of view, open doors with the sliders, jump to a selected scene, all of this without the possibilty to edit the model. this two tools will combine perfect with this idea: a bake ligth tool inside sketchup http://www.youtube.com/user/adambillyard and a video texture http://www.youtube.com/watch?v=rfr8cLZNvWg
              StarWarsKnower
              Hey, just an idea for the next SketchyPhysics, (love the boyancy by the way), could you make it so you make a line and the object attatches itself to that line. You can click and drag it to move along that line. I mean like a slider, except you can make the line bent and curved. Or the same but more like a piston where you can choose how far along the line your object is. Good luck with the next SP, and I hope you take my idea into consideration.
              Also, my dad is from ImaginationTechnologies, and is working on a 3D chip at the moment, and he loves your work.
              Thx
              StarWarsKnower πŸ˜‰
              Mike
                CPhillips
                Sorry for the delay, I just noticed this post.
                I would like to do a joint like you describe. It would make a LOT of things possible. I have tried a few times but haven't figured out how to make it yet. Its a bit more complicated than it sounds.
                Chris
                Thx
                StarWarsKnower πŸ˜‰
                • Q Offline
                  QS3D
                  Chris, I really like this plugin. I've only used it for a couple of hours though... What is the date of the latest version? Would it (will it) be possible to add animated functions to a model? say you build a tower crane; is there a way to cause it to swing left or right by pushing a key?
                    CPhillips
                    Latest released verions is SketchyPhysics2 beta 1 dated Jan 14. Next version will support keyboard controls.
                      tacianomm
                      @krisidious said:
                      oh yeah with this ruby you can make a model of our solar system, and then have collisions...
                      That's exactly what I'm trying to do.
                      But how can we simulate the orbit movement?
                      I can't figure out a way to this.
                      Does anyone have any idea?
                      πŸ˜‰
                      • W Offline
                        Wacov
                        In the super-experimental version which no-one really uses (SP3X Jun27th), you can set a body's damping. What that means is with gravity set to 0, objects will carry on moving forever unless stopped, so you can create a true orbital motion sim by setting a static 'sun' as a magnet (which actually acts more like a gravitational field), and setting the planetary bodies to magnetic. If you give them motion at the start of the sim, they should fall into orbit πŸ˜„
                        This was shown by one of CPhillip's demos, but I don't know where to find it πŸ˜•
                        Anyway, you can get Jun 27th here: http://sketchyphysics.wikia.com/index.php?title=Special:Outbound&f=SketchyPhysicsWiki&u=http%3A%2F%2Fsketchyphysics2.googlecode.com%2Ffiles%2FSetupSketchyPhysics3x-Jun27.exe, but be warned, not many people use it, since you're not supposed to share models made with it on the warehouse.
                        • 5 / 5
