    Camera following object
    4 Posts 3 Posters 9.3k Views 3 Watching
      deano40
      when you click an object in SketchyPhysics the camera follows that object. Is there a way to preselect an object for the camera to follow ❓
      P: deano40
        Jackson
        @deano40 said:
        when you click and object in SketchyPhysics the camera follows that object.
        Huh? Am I missing something or is this some new pre-alpha version of SketchyPhysics you're using? AFAIK it's not possible to make a camera follow an object in SketchyPhysics.
        Jackson
          CPhillips
          No way in current version to preselect the object. Thats a good idea tho.
          You can double click on an object to have the camera point at an object. Ctrl + double click will cause the camera to also follow the object.
            Jackson
            Never knew that- thanks for the tip!
            Jackson
