    New plugin to extrude multiple selected surfaces at once using your custom value
    3 Posts 2 Posters 1.1k Views 3 Watching
    • B
      bibarchidz
      extrude_faces_tool.rbz
      Reply Quote 2
      • Dan RathbunD
        Dan Rathbun
        Please reorganize your extension as a TRUE SketchUp extension.
        See: https://ruby.sketchup.com/file.extension_requirements.html
        Also, take note of the various numeric conversion methods that the SketchUp API has added to the Numeric class. (You do not need to write your own conversion formulae.) Here is an example that will default to model units, if the unit argument is blank:
            def convert_to_inches(value, unit = nil)
              units = Sketchup.active_model.options["UnitsOptions"]
              if unit.nil? # use model units
                case units["LengthFormat"]
                when Length::Architectural, Length::Fractional
                  return value.inch
                when Length::Engineering
                  return value.feet
                else # Length::Decimal
                  unit = units["LengthUnit"]
              case unit
              when :in, Length::Inches then value.inch
              when :m,  Length::Meter then value.m
              when :cm, Length::Centimeter then value.cm
              when :mm, Length::Millimeter then value.mm
              when :ft, Length::Feet then value.feet
              when :yd, 5
                # NOTE: constant Length::Yard (5) was added for SU2020,
                #  use 5 to avoid NameError exception in older versions.
                value.yard # yards to inches
              else
                value.inch # if inches or unknown
        Also, this is a good read for dealing with units in SketchUp:
        https://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
        I'm not here much anymore.
        • B
          bibarchidz
          thnx i will do
