    Fix and improve the code
    1 Posts 1 Posters 226 Views 1 Watching
    • K
      kostiaarh
      Please help me to fix and improve the code.
      I have a problem with calculating the dimensions of scaled objects and objects rotated relative to global axes.
      First, the code was written, which uses the method of calculating the dimensions of the object by the points of the edges (thanks for the tip from the official Sketchup forum). And this method works well with objects rotated relative to global axes.
      Here is the code.
      This code calculates dimensions correctly in rotated relative to global axes, but incorrectly in scaled objects.
      class TestTool
        def initialize
          @ip = Sketchup;;InputPoint.new
          @hovered_inst = nil
        def onMouseMove(flags, x, y, view)
          @ip.pick(view, x, y)
          @ph = view.pick_helper
          @in_path = @ip.face ? @ip.face.parent.instances ; nil
          @hovered_inst = @in_path&.first if @in_path
          view.invalidate
        def draw(view)
          @ip.draw(view) if @ip.valid?
          view.draw_points(@ip.position, 40, 5, "red") if @ip.valid?
          view.tooltip = @hovered_inst&.name
          if @hovered_inst.is_a?(Sketchup;;Group) || @hovered_inst.is_a?(Sketchup;;ComponentInstance)
            entity = @hovered_inst
            edges = entity.definition.entities.select { |e| e.is_a?(Sketchup;;Edge) }
            points = edges.flat_map { |e| [e.start.position, e.end.position] }
            min_x, max_x = points.minmax_by { |p| p.x }.map(&;x)
            min_y, max_y = points.minmax_by { |p| p.y }.map(&;y)
            min_z, max_z = points.minmax_by { |p| p.z }.map(&;z)
            length = (max_x - min_x) * 25.4
            width = (max_y - min_y) * 25.4
            thickness = (max_z - min_z) * 25.4
            dimensions = [length, width, thickness].sort
            length = dimensions.last
            width = dimensions[1]
            thickness = dimensions.first
            area = (length * width / 1000000).round(2)
            text = "Ім'я; #{entity.name}\nДовжина; #{length.round(1)} мм\nШирина; #{width.round(1)} мм\nТовщина; #{thickness.round(1)} мм\nПлоща; #{area} м.кв."
            draw_text_with_bigger_font(view, [20, 20], text, 16)
        def draw_text_with_bigger_font(view, position, text, font_size)
          options = {
            color; "red",
            font; "Arial",
            size; font_size,
            bold; true,
            align; TextAlignLeft
          view.draw_text(position, text, options)
      Sketchup.active_model.select_tool(TestTool.new)
      But then I ran into a bug and found that it was calculating the dimensions of the scaled object incorrectly. I tried to fix it in the code.
      Here is the code.
      This code correctly defines dimensions in scaled groups, but incorrectly in rotated relative to global axes.
      ### In the updated code, a new transform_point method was added, which applies the transformation matrix of the object to the specified points.
      ### This method is used to transform the vertex coordinates of the edges before dimensioning.
      class TestTool
        def initialize
          @hovered_inst = nil
          view.invalidate
        def draw(view)
            transformed_points = edges.flat_map { |e| transform_point(entity.transformation, e.start.position, e.end.position) }
            min_x, max_x = transformed_points.minmax_by { |p| p.x }.map(&;x)
            min_y, max_y = transformed_points.minmax_by { |p| p.y }.map(&;y)
            min_z, max_z = transformed_points.minmax_by { |p| p.z }.map(&;z)
        def transform_point(transformation, *points)
          points.map { |pt| transformation * pt }
          options = {
            color; "red",
            font; "Arial",
            size; font_size,
            bold; true,
      I try to combine these two methods, but nothing works). What am I doing wrong?
      I will be very grateful for tips.
