    Working with ifc-attributes
    1 Posts 1 Posters 7.0k Views 1 Watching
      artmusicstudio
      hello,
      i have to dive ibnto bim and ifc-parameters.
      i must confess, that i cnnot find the correct parameters in the compo-instance oder definitions in the ruby-api.
      so for the start
      if i iterate thru comp.-instances in the model,
      is there a way for examlple to
      -read out a table of all existing assigned (manually in the components in sketchup or imported)
      -edit them (for example changing some letters)
      • and write them again back into attributes?
      • and eventually generate a new attribute with a new value ?
      thanx for helping in advance.
      stan
      edit:
      i found out, that the ifc-attributes are similar like other attributes dictionaries, so i could read them out by
          dictionaries = mycompo.attribute_dictionaries
      # Iterates through all dictionaries and prints to screen.
      dictionaries.each { |dictionary| puts dictionary.name }
      puts ""
      attrdict = mycompo.attribute_dictionaries['dynamic_attributes']
      attrdict.each_pair { | key, value |
      puts "#{key} = #{value}"
