    MAJ Window
    3 Posts 2 Posters 5.9k Views 2 Watching
    • M
      majid866
      Hello everyone,
      “MAJ Window” extension can cut walls made by “MAJ Wall Maker” extension also can make a window match to the wall.
      Walls should be made by “MAJ Wall Maker” extension and original layers name. In the first Sketchup window select “Window Height”, “Window to WZ” and “Window Type”. “Window to WZ” is the distance between the bottom of the wall to the bottom of the window. First, click on the wall cause “Finishing Layer (Tag)” and “Interior Layer” hide. You can quit this step by clicking on “Wall” directly. Second click cause “Wall Layer” will be transparent. In this way, you can see the 2D plan or other elements covered by the wall. You can select the first side of the window with a third click. The fourth click will select another side of the window. After the fourth click, 3 wall layers cut and window match to the wall will make.
      "MAJ Window" extension is published in EWH.
      Please let me know your idea about this extension.
      Type A
      Type B
      • pbacotP
        Thank you!
        May I suggest a protocol: To be able to set a default to the TOP of the window. It is more common that the tops of windows will be the same height. Then one can complete windows in a building without adjusting the setting.
        I would also suggest for the size: keyboard input, or tool continues to put the size of the last window that you used.Because simply clicking is inaccurate and because you often insert identical windows
        • M
          majid866
          @pbacot said:
          Thank you!
          I would also suggest for the size: keyboard input or tool continues to put the size of the last window that you used. Because simply clicking is inaccurate and because you often insert identical windows
          I agree with you that windows should be at the same height but also I will have MAJ Door extension and for doors size from the bottom of the wall is important. I wish to have the same standard for both extensions.
          Your other suggestion will have some advantages and some disadvantages. Also, it is possible to have one more click and select the height of the window. Also, I wish to keep the simplicity of extensions. Let me think more about it. I hope to hear more suggestions.
