    MAJ Stair Plugin
    17 Posts 6 Posters 15.7k Views 6 Watching
      majid866
      Dear Friends,
      My new plugin ("MAJ Stair") is published in "Sketchup Extension Warehouse" for free now. I think you can make stairs in any shape by using this plugin. Please let me know your idea about it.
      Majid Mahmoudi Video: https://www.youtube.com/watch?v=hU_nJDRwEJc
      The new version "MAJ Stair V0.0.2" is published. I used HTMLDialog on it. Please let me know your idea about it.
      • jujuJ Offline
        juju
        Do you perhaps have video tutorial? The EW page mentions 4 different kinds of stairs but 2 of those look very much the same (apart from structure thickness).
          majid866
          @juju said:
          Do you perhaps have video tutorial? The EW page mantions 4 different kinds of stairs but 2 of those look very much the same (apart from structure thickness).
          For thickness you have 4 types but shape you can make any kind of stair. I will send you video soon.
            majid866
            https://youtu.be/MhSFryAkUOo
            Please watch video..
            • jujuJ Offline
              juju
              Interesting methodology. Depending on time I might give it a try. Any chance you could get it to work that you select the line drawing and have it extrude the stairs from that? Obviously there will be another click or two involved to indicate start and end.
                majid866
                Please check video again. Any kind of stair by using this method will be possible.
                • pbacotP Offline
                  Looks like very good and straightforward plugin.
                    rv1974
                    Majid, thank you for creating and sharing this nice tool, it has a great potential!
                    A couple of ideas:
                    *) Most important: please give an option to set the general stairs height with 2 mouse clicks;
                    *) Could it build some primitive railings (as lines, posts (simple vertical line) could be the instances of a single component)?
                    *) non-modal window?
                    *) Could you add previews of different stair styles in plugin window? Now you have lots of empty space in the left area for no reason
                    *) Those fillets on upper tiles are not too successful.. could there be simple 90 degr. cut?
                      majid866
                      A couple of ideas:
                      Dear rv1974,
                      Thank you for your nice ideas. Window of this plugin come from Sketchup User Interface (UI) and it limit us so much. Empty space come from UI and we cannot have any graphic there just can have some letters. I will be happy if you have some suggestion for it.
                      about "General Stair Height" if you mean stair total height you have it in window just select it. Please see attached photo.
                      Railing will be more difficult than stair and need another version.
                      Can you send me photo sample for "non-modal window" and "fillet on upper tiles"? Do you mean stair nosing?
                        rv1974
                        Majid thanks for reply,
                        Regarding empty space\explaining pictures.. I can hardly believe the empty space and absence of explaining pictures are inevitable. Maybe other scriptwriters on dev forums could help you on the subject? For example please take a look here:
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=71459
                        Taking general floor measurements is much more user friendly, plus adds certain flexibility
                        especially in conjunction with non-modal window (See 'Take measurements' in attached plugin)
                        By non-modal I mean constantly floating window that does not block using SU. Again try the link I attached. Yes, I meant fillets on nosing. They are not suitable in majority of cases.
                        Still hoping eventually edge railings will be added. What about save\load preset?
                        Thank you for attention
                          joshbrown
                          That's right! This plugin is decent. I am using it myself.
                          Hey guys! I want to show you my professional essay writing services. Use them if you need any writing assistance.
                            dtroyuf
                            Hi, I am enjoying the Maj Stair Plugin, but I the 'X' button for breakpoints is not working with your plugin. I am working on a MAC, OS Big Sur and I am using SU2020. Have you noticed this issue before on Mac's? Or is there a way to resolve this issue. Again, I really enjoy your plugin, but not being able to make breakpoints is frustrating. Thank you! -David
                              majid866
                              A couple of ideas:
                              I think my new extension (MAJ Rail) can solve the stair railing problem.
                                majid866
                                Dear friend,
                                Please forgive me to answer you late. I solved this problem in version 0.0.3 and it is in the queue. I will inform you whenever the new version published.
                                  dtroyuf
                                  @majid866 said:
                                  Dear friend,
                                  Thank you for the response back. I look forward to using the updated version!!
                                  -david
                                    majid866
                                    @dtroyuf said:
                                    @majid866 said:
                                    Dear friend,
                                    -david
                                    Hi, "MAJ Stair" version 0.0.3 is published now. I wish you will enjoy it.
                                      dtroyuf
                                      @majid866 said:
                                      @dtroyuf said:
                                      @majid866 said:
                                      Dear friend,
                                      -david
                                      I just tried it out, and it works great on a Mac!! Thank you for making that update, I really appreciate it!!
                                      -David
