    Help with sketchyphysics moving a crank
    3 Posts 2 Posters 6.9k Views 2 Watching
    • F
      Frannkifly
      I made a simple model in SU . The purpose is to move a block with an bend hing road passing trough its slot , just like a crank mechanism .
      I tried everything, but I could not move it the right way.
      Can somebody help me please !
      T.I.A.
      Franky
      Example
        For your problem i suppose you must "trim" the object (who must be moved by another thing) in simple boxes ! (so here 3 vertical 3D boxes)
        Then grouped
        (i have not open your file)
        Better now is now use MS Physics ( i believe Sketchy Physics is no more developped)
        Here a complete tutorial (26 steps)
        • F
          Frannkifly
          Pilou thank you in advance.
          As you said , I made three separate blocks ( each one is a single group ), than what ?
          Next step is to group them again ?
          I do not understand what next .
