    [Plugin] MAJ Wall Maker
    4 Posts 2 Posters 5.7k Views 2 Watching
    • M
      majid866
      My name is Majid Mahmoudi. As a SU user, I really enjoy this software but it was difficult for me to draw building base on 2D plan and sometimes I used other software for it. MAJ Wall Maker is a plugin that can draw a wall in 3 layers and simply can do it base on 2D plan. My next extension is "MAJ Door Cutter". This extension transparent wall that made by "MAJ Wall Maker" and you can see 2D Plan and follow it for door / Window holes. I hope my plugins will be acceptable at SCF’s PluginStore.
      Best regards,
      • srxS
        srx
        Hello. Thank you for giving your plugin for free. It could be vary useful. My first notice is that I could not make a wall with external layer thicker than 10cm. Why this limit?
        www.saurus.rs
        • M
          majid866
          Hi, General idea is make a wall simply and close to real. I never see a wall with finishing layer more than 10CM. Also some other plugins will come after this one that will use it and I need to consider some limitation for future. You can draw 2 walls and change layer on one to "Finishing" for solution.
          Best regards
          • srxS
            srx
            Best regards
            😎 Lucky you. It is ☀ at your place.
            www.saurus.rs
