    MSPhysics: Collision Detection Offset and Joint Limits
    6 Posts 2 Posters 8.6k Views 2 Watching
    • Tim DanaherT Offline
      Tim Danaher
      Well, three years later and I finally get around to it...
      I've got my design set up in MSPhysics (see my earlier post about one-handed brake lever design), but there always seems to be a 'barrier' around objects: I can't get them to touch, so the bottom lever never pivots. I can pivot it on its own, but can't get it to pivot using the upper lever blade.
      https://live.staticflickr.com/65535/49757305771_2d60631a67_b.jpg
      Everything is modelled to scale.
      I've searched, but I can't find anything about setting offsets for collision detection. Similarly nothing for limiting joint movement between certain angles (so objects don't spin freely). Can I do this?
      TIA
      Cheers,
      Tim
      http://vizarch.blogspot.com
      • ecatiE Offline
        ecati
        Can you share the skp file?
          Tim Danaher
          Sure. What's the best way? Put it on the 3D Warehouse?
          Cheers,
          Tim
            Tim Danaher
            It's on 3D Warehouse as Ergopower OHBL
            Cheers,
            Tim
            • ecatiE Offline
              ecati
              If you mark "Collision Wireframe", you can see how the parts touch each other (picture 1).
              You can fix this error by grouping the pieces separately (picture 2).
              picture 1
              picture 2
              Ergopower_OHBL_ecati.skp
                Tim Danaher
                Thanks ecati! Odd, I didn't get a notification... I'll have a look at this later...
                Cheers,
                Tim
