    Need some help withMSPhysics script
    1 Posts 1 Posters 5.6k Views 1 Watching
    • J
      Johnsketch
      Hi, i'm just started with using script in ms physics. I see the potential, but its hard to find samples or good tutorials about it. For example, i use this script for different servo's
      onStart{
      set_var("schuif",0)
      onClick{
      if get_var("schuif")==0
      set_var("schuif",9)
      else
      set_var("schuif",0)
      This script make's a piston go 0ne direction on click, and go back on the next click.
      Is it possible te slider goes back to 0 without the second click? Meaning it goes to 9 en then returns to 0 ?
      I use a similar script to rotate an object 45 degrees on each clikck, but this script allows me only 3 clicks. Is there a way to extend the number of clicks?
      Hope someone can help me out with this
