    Resolve [Ruby help] Script for create window sills
    3 Posts 2 Posters 8.5k Views 2 Watching
      benj59380
      Hello , Today I wanted Creat script for window sills
      my approach is create face manuel
      click for select
      run script
      ( part 1 : select face , creat color , Push -30 mm
      Part 2 : select vertical face for push +30)
      Part 1 work , but Part 2 fail 😞
      But Ruby = SyntaxError help me please for resolve the problem 😉
      thank you in advance , Benjamin
      #part 1
      model = Sketchup.active_model
      ent = model.entities
      sel = model.selection
      ad = sel.ent
      faces = []
      sel.each do |e|
      faces <<e if e.is_a? Sketchup::Face
      faces.each do |appui|
      appuicolor = Sketchup::Color.new(238,130,238)
      appui.material = appuicolor
      appui.back_material = appuicolor
      status = appui.pushpull(-30.mm , true)
      #part 2
      ad.each do |e|
      s=Sketchup.active_model.selection;
      a=s.to_a;s.clear;
      a.grep(Sketchup::Face).each{|f|s.add(f)if f.normal.z==0}
      faces.each do |facade|
      status = facade.pushpull(30.mm )
      • sdmitchS Offline
        sdmitch
        Part 1 works if you delete or comment out the ad=sel.ent statement which is invalid.
        Part 2 doesn't work because the faces created by the pushpull operation are not automatically added to the selection. Also you reuse the faces array which only contains the original faces selected.
        Here is how I would do it
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        SKETCHUP_CONSOLE.clear
        appuicolor = Sketchup;;Color.new(238,130,238)
        sel.grep(Sketchup;;Face).each do |appui|
          old = ent.to_a
          new = ent.to_a - old
          new.grep(Sketchup;;Face).select{|f|f.normal.z==0}.each{|f|f.pushpull 30.mm}
        http://sdmitch.blogspot.com/
          benj59380
          hello , Thank you SDMITCH for help 😉
          cordially Benj
