    Component Axes
    3 Posts 2 Posters 7.9k Views 2 Watching
    • H Offline
      honkinberry
      When I create a component via .add_group and then .to_component, the component axes are set to the lower left extremities. Meanwhile, making a component via the Edit menu, I can specify the Component Axes in the dialog.
      How can I set or move the component axes when I create the definition via Ruby?
      Many thanks for any assistance!
      --J
      • Dan RathbunD Offline
        Dan Rathbun
        FYI, You can change the insertion point insertion_point=.
        You can also apply a transform to the entire entities of the definition ...
        ctr = cdef.bounds.center # Center of untransformed bounds
        # Arrays are compatible with translational transformations;
        xform = [ctr.x, ctr.y, 0].vector_to(ORIGIN)
        cdef_ents = cdef.entities
        # Move all the entities so that the axis is in the bottom center;
        cdef_ents.transfrom_entities(xform, cdef_ents.to_a)
        I'm not here much anymore.
        • H Offline
          honkinberry
          Boom! That worked!
          Thank you sir!
          --J
