    Send_to_layout or Layout::Document.open(filename)
    1 Posts 1 Posters 5.7k Views 1 Watching
      sjn001tvh
      I seemed to have hit another road block. This time in terms of trying to use the send_to_layout method within Sketchup.
      My objective is as follows:
      1. create a routine that creates a copy of any of the selected assembly to a single component
      2. save that component to a file
      3. open the file and separate each component so that it is viewed from a side view
      4. space them apart within a Scene based on predefined margins
      5. send each Scene to a Layout file, each Layout Page/Sketchup Scene
      6. then manipulate the Layout tools to attach the dimensions to each object
      But I can't seem to get past getting Sketchup to create a new Layout file.
      Using the console here's what happens. I created the directory and made sure it existed.
      x_layoutDir = x_dirPath + "/" + "LayoutSets" Dir.exist?(x_layoutDir) true
      Then used send_to_layout to create a new Layout file.
      x_result = Sketchup.send_to_layout(x_layoutDir + "/MyTestLayoutFile.layout") false
      No luck. Found another command and tried it.
      objLayout = Layout::Document.open(x_layoutDir + "/MyTestLayoutFile.layout") Error: #<ArgumentError: File does not exist> <main>:inopen'
      <main>:in <main>' SketchUp:1:in eval'`
      No Luck. Found another option by just using the send_action.
      Sketchup::send_action("sendToLayOut:") false
      Again no luck. So, I tried this from another angle. I first created the file.
      objLayout = Layout::Document.open(x_layoutDir + "/MyTestLayoutFile.layout") #<Layout::Document:0x0002751b936538>
      Success!!!
      However, it was somewhat short lived, because I couldn't view the file from Layout that I had just opened. And even though it appeared to be successful I couldn't get Layout to open so that I can view the results of using the methods.
      Plus, it brought up another question. Is there a way to have Sketchup create and open the Layout file, without having to have a file already existing?
      I tried...
      objLayout = Layout::Document.new(x_layoutDir + "/MyNewLayoutFile.layout") Error: #<ArgumentError: The template file could not be found> <main>:ininitialize'
      <main>:in new' <main>:in <main>'
      SketchUp:1:in eval'
      I couldn't find where I could implement Layout template file and when I created a Layout template file, there wasn't any type of method that would allow me to create new file using it.
      So, I would like to have 2 questions answered.
      1. How do I get Sketchup to create a new Layout file?
      2. Is there a method to open the Layout application and view the document that was just opened using the Layout::Document.open method?
      Thanks,
      Scott.
