Load plugin on condition of textfile
I have an excel file that opens sketchup, creates the drawing, then closes sketchup.
NOTE:
I have changed my way of thinking, now before excel opens sketchup, it will change a word in a text file to "go", then when the plugin works it's magic, it will change the word in the textfile to "no go"It still seems to load the plugin even it the textfile is "no go"
File.open("C:/TestFolder/Doit with Sketchup/RunPlugIn.txt").each do|line| puts line UI.messagebox line if line == "go" load "testOpenSketchup.rb" UI.messagebox "Go" elseif line=="no go" puts "Nope" end end -
Okay, I found a solution, I should have had the if statement in the plugin I wanted to run.
Register LoginAdvertisement
