    Set the last column of a Geom::Transformation
    2 Posts 2 Posters 3.5k Views 2 Watching
    • V
      Voulz
      Hi Guys,
      I am working on a plugin handling projections where I end up creating my own transformation matrices. I was getting weird results and it took me a while to see that SketchUp was discarding some data from the last column , which is problematic in my case.
      Geom;;Transformation.new([1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16]).to_a
      >> [1.0, 2.0, 3.0, 0.0, 5.0, 6.0, 7.0, 0.0, 9.0, 10.0, 11.0, 0.0, 13.0, 14.0, 15.0, 16.0]
      (note the missing items #3,#7,#11 keeping the value 0.0)
      Do you know why and if there is any workaround?
      Thanks!
      • F
        faust07
        You may find information on this in:
        "Automatic SketchUp - Creating 3-D Models in Ruby"
        by Mathew Scarpino
        Permissions may be sought directly from Eclipse Engineering LLC:
        Fax: (925) 262-1757
        E-mail: info@eclipseengineer.com
        Appendix B: Advanced Geometry..................................... 391
        B.3 Introduction to Transformation Matrices .........................................406
        B.4 Combinations of Transformations...................................................415
        B.5 Transforming Points and Vectors....................................................418
        B.6 Mathematics of Combining Transformations....................................423
        You may find helpful links here:
        http://sketchucation.com/forums/viewtopic.php?f=180&t=10142&p=573943&hilit=automatic+sketchup#p269709
