    New for sketchup 2017 - help Edit mode parametric.rb
    1 Posts 1 Posters 2.9k Views 1 Watching
    • D
      degele
      Goodmorning everyone
      I ask for help to complete EDIT mode
      based on parametric.rb scripts
      a99 = selected faces array (debug)
      mullion: to do
      thanks
      Sorry for English lev
      require 'sketchup.rb'
      require 'SOFTDEG_vetrate/parametric.rb'
      module SOFTDEG_Vetrate
      class Vetrate < SOFTDEG_Vetrate;;Parametric
      #original offset by Rick Wilson
      #Smustard
      def offset_(face=nil, dist=0)
          return nil if not face or not face.valid?
      	return nil if (not ((dist.class==Fixnum || dist.class==Float || dist.class==Length) && dist!=0))
          pi=Math;;PI
      	verts=face.outer_loop.vertices
      	pts=[]
      	0.upto(verts.length-1) do |i|
      		vec1=(verts[i].position-verts[i-(verts.length-1)].position).normalize
      		vec2=(verts[i].position-verts[i-1].position).normalize
      		vec3=(vec1+vec2).normalize
      		if vec3.valid?
      			ang=vec1.angle_between(vec2)/2
      			ang=pi/2 if vec1.parallel?(vec2)
      			vec3.length=dist/Math;;sin(ang)
      			t=Geom;;Transformation.new(vec3)
      			if pts.length > 0
      				if not (vec2.parallel?(pts.last.vector_to(verts[i].position.transform(t))))
      					t=Geom;;Transformation.new(vec3.reverse)
      				end#if
      			end#if
      			pts.push(verts[i].position.transform(t))
      		end#if
      	end#upto
      	face.parent.entities.add_face(pts) if pts[2]
        end#offset_
      # Crea vetro doppio, singolo con spessore (thick_v) 0 oppure senza vetro con spessore (thick_v) negativo
      def vetro(newFace,  width, thick, d_a, thick_v, container)
      	frame = container.add_group
      	group_container = frame.entities
      	if thick_v == 0.mm
      		thick_v=1.mm
      		thick_vv=0.mm
      	da=d_a+(thick-thick_v)/2
      	intFace=offset_(newFace,-width)
      	telaio_i = intFace.outer_loop.vertices
      	telaio_i = group_container.add_face(telaio_i)
      	if not telaio_i.normal.z == 1
      		telaio_i.reverse!
      	status = telaio_i.material = "vetro_01"
      	status = telaio_i.back_material = "vetro_01"
      	vetro1=telaio_i.pushpull((da+thick_v),true)
      	telaio_i.pushpull(da+(thick_v/2))
      	@entities.erase_entities(telaio_i.outer_loop.edges,intFace.outer_loop.edges)
      	intFace = offset_(newFace,-width)
      		telaio_i.reverse!
      	if not thick_vv == 0.mm
      		vetro2 = telaio_i.pushpull(da,true)
      	else
      		@entities.erase_entities(telaio_i, telaio_i.outer_loop.edges,intFace.outer_loop.edges)
      	newFace.erase!
      	frame
      end #def
      # Crea telaio/anta/cornice mediante dimensioni e sfalsamento in asse e offset dalla faccia di partenza (foro muratura)
      def anta(newFace1, d_o, d_a, width_a, thick_a, container)
      	newFacet = newFace1.outer_loop.vertices
      	newFacet = container.add_face(newFacet)
      	if  d_o == 0.mm
      		newFace = newFace1
      	else
      		newFace = offset_(newFacet,d_o)
      		newFacet.erase!
      	intFace = offset_(newFace,-width_a)
      	telaio_e = newFace.outer_loop.vertices
      	telaio_e = group_container.add_face(telaio_e)
      	telaio_i.erase!
      	status = telaio_e.material = "legno_01"
      	if not telaio_e.normal.z == 1
      		telaio_e.reverse!
      	anta1=telaio_e.pushpull((d_a+thick_a),true)
      		telaio_e.reverse!
      	telaio_e.pushpull -d_a
      	if not d_o == 0
      		@entities.erase_entities(newFace.outer_loop.edges, intFace.outer_loop.edges)
      	else
      		@entities.erase_entities(intFace.outer_loop.edges)
      		newFacet.erase!
      	frame
      end #def
      def create_entities(data, container)
      	# Set values from input data
      	a99 = data["a99"] # faccia di partenza
      	a0 = data["a0"].to_l # Cornice esterna Larghezza
          a1 = data["a1"].to_l # Telaio infisso Larghezza
      	a11= data["a11"].to_l # Lista rifinitura interna Larghezza
          a2 = data["a2"].to_l # Spessore Vetro
      	a3 = data["a3"].to_l # Stecche oriz. Larghezza
      	a4 = data["a4"].to_l # Stecche vert. Larghezza
      	a5 = data["a5"].to_int # N Stecche orizzontali
      	a6 = data["a6"].to_int # N Stecche verticali
       	# Remember values for next use
      	@@face = a99
      	@@width_c = a0
      	@@width_a = a1
      	@@lista_w = a11
      	@@thik_v = a2
      	@@width_so = a3
      	@@width_sv = a4
      	@@ns_o = a5
      	@@ns_v = a6
      	# imposta costanti
      	anta_a=20.mm 	# Sfalsamento anta dal telaio
      	thick_c=70.mm 	# Spessore Cornice
      	thick_a=70.mm 	# Spessore Infisso Anta
      	lista_t=10.mm	# Spessore lista interna
      	lista_d_a=20.mm	# Sfalsamento lista dall'anta
      	# Inizio creazione vetrata
      	model = Sketchup.active_model
          @entities = model.active_entities
          sel = model.selection
      	# Definisce i due materiali utilizzati
      	mats=model.materials
      	if mats["legno_01"]==nil
      		legno=mats.add("legno_01")
      		legno.color="Brown"
      	end#if
      	if mats["vetro_01"]==nil
      		vetro=mats.add("vetro_01")
      		vetro.color="Gray"
      		vetro.alpha=0.25
      	end#if
          if Sketchup.version_number < 7000000
              model.start_operation "Vetrate"
          else
              model.start_operation "Vetrate", true
      	faces = sel.select{|e| e.typename == 'Face'}
      	#if not faces.length > 0
      	#end
          model.start_operation("Crea Telaio")
      	faces.each do |face|
      		#crea gruppo della faccia originale
      		tgroup=@entities.add_group
      		tentities=tgroup.entities
      		iface=face.outer_loop.vertices
      		oface=tentities.add_face(iface)
      		#crea telaio esterno
      		newFace0=oface
      		cornice_o=a0
      		cornice_a=0.mm
      		cornice=anta(newFace0,cornice_o,cornice_a, 2*a0, thick_c, container)
      		#crea lista di finitura interna
      		if a11 > 0
      			newFace1=oface
      			# ottimizza sfalsamento cornice finitura interna
      			if a0 < lista_d_a
      				lista_d_a=a0/2
      			lista_o=lista_d_a+a11
      			lista=anta(newFace1, lista_o, thick_c, a11, lista_t, container)
      		#crea anta interna
      		if a1 > 0
      			newFace2=oface
      			anta_o = 0.mm
      			anta=anta(newFace2,anta_o, anta_a, a1, thick_a, container)
      		else
      			a1=a0
      			anta_a=0
      		#crea vetro
      		newFace3=oface
      		if a2 >= 0.mm
      			vetro=vetro(newFace3, a1, thick_a, anta_a, a2, container)
      		face.erase!
      		tgroup.erase!
          model.commit_operation
      end #end def
      def default_parameters
      		# Set starting defaults
      		if !defined? @@width_c  # then no previous values input
      			defaults = {"a0" => 40.mm, "a1" => 80.mm, "a11" => 70.mm, "a2" => 30.mm, "a3" => 40.mm, "a4" => 40.mm, "a5" => 0, "a6" => 0 , "a99" => nil }
      		else
      			# Reuse last inputs as defaults
      			defaults = {"a0" => @@width_c, "a1" => @@width_a, "a11" => @@lista_w, "a2" => @@thik_v, "a3" => @@width_so, "a4" => @@width_sv, "a5" => @@ns_o, "a6" => @@ns_v, "a99" => @@face  }
      		end # if
      end # default_parameters
      def translate_key(key)
          prompt = key
          case( key )
              when "a0"
      			prompt = " Cornice esterna Larghezza "
      		when "a1"
      			prompt = " Telaio infisso Larghezza "
      		when "a11"
      			prompt = " Lista rifinitura interna Larghezza "
      		when "a2"
                  prompt = " Spessore Vetro "
      		when "a3"
      			prompt = " Stecche oriz. Larghezza "
      		when "a4"
      			prompt = " Stecche vert. Larghezza "
      		when "a5"
      			prompt = " N Stecche orizzontali "
      		when "a6"
      			prompt = " N Stecche verticali "
          prompt
      end # Class Vetrate
      if (not $Vetrate_menu_loaded)
      	### commands
          cmd1=UI;;Command.new("SOFTDEG_Vetrate") { Vetrate.new }
      	cmd1.tooltip='Vetrate Irregolari Parametriche - donazione PayPal; tiziano.traini@tin.it'
          cmd1.status_bar_text='Vetrate Irregolari; Seleziona una faccia ...'
          cmd1.small_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_16x16.png')
          cmd1.large_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_24x24.png')
      	menu=UI.menu("Tools").add_item(cmd1)
      	toolbar=UI;;Toolbar.new('SOFTDEG_Vetrate')
          toolbar.add_item(cmd1)
          toolbar.restore if toolbar.get_last_state.abs==1 #TB_VISIBLE/NEVER
      	$Vetrate_menu_loaded = true
      end # module SOFTDEG_Vetrate
      SOFTDEG_vetrate.rbz
      SOFTDEG.skp
