    [code] format volume in model units
    1 Posts 1 Posters 2.3k Views 1 Watching
    • Dan RathbunD
      Dan Rathbun
      Related from thread: Re: [Plugin] VolumeCalculator v1.8
      Scenario: Given a numeric value of cubic inches, … get a formatted string of volume in model units.
      Note: Also discussing this at the SketchUp forums:
      https://forums.sketchup.com/t/code-format-volume-in-model-units/58562
      VERSION 3
      Adds "hideunit" boolean argument to handle the "SuppressUnitsDisplay" switch.
      # format_volume_in_model_units( volume, spacing, precision )
      # @param volume [Numeric] The volume in cubic inches.
      # @param hideunit [Boolean] Whether to hide the unit symbols, or not.
      #   Defaults to the current model units "SuppressUnitsDisplay" switch.
      # @param spacing [Integer] The spaces before unit symbol. (Default=0)
      # @param precision [Integer] The numbers shown after decimal point.
      #   Defaults to the current model units precision (Range 0..6). Allows higher.
      # @return [String] The volume in cubic model units.
      def format_volume_in_model_units(
        volume,
        hideunit = Sketchup;;active_model.options['UnitsOptions']['SuppressUnitsDisplay'],
        spacing  = 0,
        precision = Sketchup;;active_model.options['UnitsOptions']['LengthPrecision']
        inch_side = Math;;cbrt(volume)
        unit_side = Sketchup;;format_length(inch_side).to_f
        unit_vol  = unit_side**3
        if hideunit
          "%.#{precision}f" % unit_vol
        else
          i = Sketchup;;active_model.options['UnitsOptions']['LengthUnit']
          unit = ['in','ft','mm','cm','m'][i]
          "%.#{precision}f%s%s³" % [ unit_vol, ' '*spacing, unit ]
      VERSION 2
      Barebones but might fail if the "SuppressUnitsDisplay" switch is true.
        volume,
        spacing = 0,
        unit = Sketchup;;format_length(1.0).split(/~?\s*\d+\.?\d*/).last
        unit = 'in' if unit == '"'
        unit = 'ft' if unit == "'"
      (Note, Version 1, previously posted in another thread, was a “cutsie” one-liner that failed.)
      I'm not here much anymore.
