    Stopping script execution
    6 Posts 2 Posters 3.1k Views 2 Watching
    • F
      Fancey
      I have a number of 3D lines which I can load from a file and draw in the Sketchup window with a script via the ruby console. I would like to be able to step through the lines one at a time. I suspect it's not available because of the working environment. gets, chomp, STDIN does not work.
      Code would look like this:
      Until no_more_lines
          ent.add_edges line
          #wait for key board activity at the console
       next # line
      Any suggestions appreciated
      • D
        driven
        use IO::readlines to create an array...
        create a method that uses one pair of points and then removes them from the array...
        call the method...
        use the UP arrow and return in Ruby Console to call again...
        rinse and repeat until array is empty...
        add an example text file for more explicit code...
        john
        • F
          Fancey
          Hi John,
           Thanks for the suggestion.  Will see what I can do with it.
          Everett
          • F
            Fancey
            Hi John,
            Got it working. Thanks for pointing me in the right direction. Had to do a bit of learning along the way. I used the CSV and JSON classes. My main script read the original data, processed it into 3d points, and produced an array of lines. After I got all the lines working, I added a block to write the array to file. The second script reads this file, draws a single line, removes it from the array, and writes the array back to file. Here's the pseudo code for the second script:
            access the entities container
            load required classes
            [pre:2k0pic0s]require "CSV"
            require "JSON"[/pre:2k0pic0s]
            take a working copy of the file
            check each time through
            unless File.exist? <filename>
            [pre:2k0pic0s]#take a copy[/pre:2k0pic0s]
            load the lines into an array
            [pre:2k0pic0s]line_arr = CSV.read(<filename>)[/pre:2k0pic0s]
            convert points from string to array of floats
            this caused the most grief until I got it right
            [pre:2k0pic0s]line_arr.map! {|line| line.map {|pt| JSON.parse(pt)}}[/pre:2k0pic0s]
            #draw a line
            [pre:2k0pic0s]ent.add_edges line_arr[0][/pre:2k0pic0s]
            #dump the line
            [pre:2k0pic0s]line_arr.shift[/pre:2k0pic0s]
            #replace the array in the file after checking for last line
            if <last line>
            [pre:2k0pic0s]File.delete(<filename>)[/pre:2k0pic0s]
            else
            [pre:2k0pic0s]CSV.open(<filename>,"wb") do |csv|
            [pre]line_arr.each{|x| csv<< x}[/pre:2k0pic0s]
            end[/pre]
            #use the up arrow to execute as many times as lines
            • D
              driven
              it looks a bit over complicated...
              do you really need JSON when you can use CSV with a options hash...
              @ary = CSV.read( file, { headers; false, converters; ;numeric } )
              here's a little experiment to step using the mouse wheel...
              you may need to 'click' to run the gif...
              change the path to file...
              class UseViewZooming
                require 'CSV'
                # Called when you start the tool
                def activate
                  puts "activate called"
                  @pt = 0
                  file = '/private/tmp/csv_test/test.csv'
                  @model = Sketchup.active_model
                  @ents  = @model.entities
              	# Called when you run out of pts, select another tool or quit SketchUp
              	def deactivate(view)
              		puts "deactivate called"
              	def draw(view)
              		if @pt + 1 == @ary.length
              			@ents.grep(Sketchup;;Edge).last.find_faces
              			return Sketchup.active_model.select_tool( nil)
              		pt1 = @ary[@pt]
              		pt2 = @ary[@pt + 1]
              		@ents.add_line([pt1, pt2])
              		@pt +=1
              end # end of class UseViewZooming
              Sketchup.active_model.select_tool( UseViewZooming.new )
              • F
                Fancey
                I did think it was a bit complicated myself. Most of my programming experience was years ago on 3rd GL stuff. All this is new, but I do have fairly good programming sense.I did try the CSV modifier, but I wasn't using it correctly. That's when I stumbled on JSON. It's only a one shot deal for me, but I have to admit, I do like Ruby! Will be studying your example.
                Thanks again.
                Everett
