    Remove dynamic attributes in ruby
    5 Posts 3 Posters 2.8k Views 3 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      **Hello everyone ☀
      edit:
      To add a dynamic attribute to all instances in SketchUp, proceed as follows:
      def add_attribute
          mod = Sketchup.active_model
          mod.definitions.each do |d|
          d.instances.each do |i|
          d.set_attribute 'dynamic_attributes', 'lola','10'
          i.set_attribute 'dynamic_attributes', 'lola','10'
      add_attribute
      To remove this attribute without affecting all the dictionary, you have to do like this:
      def delete_attribute
          d.delete_attribute 'dynamic_attributes', 'lola'
          i.delete_attribute 'dynamic_attributes', 'lola'
      delete_attribute
      If I change the value of the attributes manually on SketchUp, the deletion will no longer be possible!
      How to get around the problem?
      Thank you**
      • jujuJ Offline
        juju
        Eneroth De-DC-ify
        • TNTDAVIDT Offline
          TNTDAVID
          **The opening of my TOPIC on the cleaning of dynamic components, motivated other developers to look into the problem.
          The rb file is cripté thus impossible to read it.
          In addition, this example does not answer the functions that I am currently looking for.
          Thanks anyway juju**
          • TNTDAVIDT Offline
            TNTDAVID
            **I did not take the time to re-read my code and I was wrong in my examples!
            To add a dynamic attribute to a selected component:
            def add_attribute_in_selection
                sel = mod.selection
                sel.each do |s|
                s.set_attribute 'dynamic_attributes', 'lola','1'
            And to remove it:
            def delete_attribute_in_selection
                sel = mod.selection
                sel.each do |s|
                s.delete_attribute 'dynamic_attributes', 'lola'
            My first example adds a dynamic attribute to all instances in SketchUp.
            Sorry for this mistake for lack of attention!
            ps: I still have not found how to remove a custom attribute created with SketchUp.**
            • Dan RathbunD Offline
              Dan Rathbun
              David, why are using this crazy indentation ?
              Ruby uses 2 space indents, and all code at the same level must be at the same indent:
              This way the beginning of blocks line up with the indent lines in code editors.
              I'm not here much anymore.
