    Rbclipper in sketchup 2017
    2 Posts 1 Posters 1.6k Views 1 Watching
    • B
      biervat
      I'm trying to use the rbclipper library in sketchup 2017 pro x64 using this tutorial:
      http://dagrende.blogspot.be/2011/08/install-rbclipper-in-sketchup-8.html
      But instead of ruby 1.8.7 I used 2.2.4 and instead of DevKit-tdm-32-4.5.2-20110712-1620-sfx.exe I used DevKit-mingw64-64-4.7.2-20130224-1432-sfx.exe
      When I try running it in Sketchup I get this error
      require 'clipper'
      Error; #<LoadError; 126; The specified module could not be found.   - C;/Users/maarten/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/clipper.so>
      C;/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;54;in `require'
      <main>;in `<main>'
      SketchUp;1;in `eval'
      What am I doing wrong?
      • B
        biervat
        I got it working. I used the ruby-c-extension-example to create a visual studio 2017 project and compiled it. You can find the VS2017 project in the link and compile it or use the so in releases if you have Sketchup 2017 x64.
        https://drive.google.com/open?id=1Ulz8sNDuyg2dY9Yy1vIW_thEOhAtIq2L
