    Method or plugin for subdividing like this sample
    31 Posts 7 Posters 7.1k Views 7 Watching
    • C
      cesaro36
      Hi everyone
      Is there any plugin or code snippet that creates this kind of subdivision, basically is a offset from each edge in a solid component?
      My goal is to smooth corners at objects prior to any rendering.
      Corner subdivision
      Saludos
      • sdmitchS
        sdmitch
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        vue = mod.active_view; pts =[]
        sel.grep(Sketchup;;Face).each{|f|
         vec = f.normal.reverse
         pts << f.vertices.map{|v|v.position.offset(vec)}
        pts.each{|p| f=ent.add_face(p); f.erase!}
        http://sdmitch.blogspot.com/
        • C
          cesaro36
          How simple you make it look like.
          Thanks. I'll dig into it.
          • PixeroP
            Pixero
            Thanks for the code Sam. πŸ‘
            It works great for the example where faces are perpendicular but not with something with non perpendicular faces. See attached SKP (SU8). Could that be added?
            Offset problems.skp
            • sdmitchS
              sdmitch
              sel = mod.selection
              faces = sel.grep(Sketchup;;Face)
              faces.each{|f|
               vec = f.normal.reverse; ctr = f.bounds.center
               pts << f.vertices.map{|v|v.position.offset(ctr.vector_to(v.position)).offset(vec)}
              grp=ent.add_group; ge=grp.entities; gt=grp.transformation
              pts.each{|p|
               fgrp=ent.add_group;fge=fgrp.entities;fgt=fgrp.transformation
               f=fge.add_face(p);
               fge.intersect_with false,fgt,ge,gt,false,faces
               fgrp.erase!
              grp.explode
              • PixeroP
                Pixero
                I tried the new code and it's better but for other non perpendicular faces it still gives some weird results.
                A cylinder for example.
                I have attached another example of that below. Hopefully it's possible to get it right for these cases also.
                Offset errors 2.skp
                • sdmitchS
                  sdmitch
                  @pixero said:
                  A cylinder
                  The initial request was for a simple box.
                  • PixeroP
                    Pixero
                    But the code was so useful I couldn't help myself wanting it to work on more types of objects...
                    ...what if I say: please?
                    • JQLJ
                      JQL
                      I see a lot of possibilities here.
                      Fake beveling at render time?
                      Please Sam?
                      www.casca.pt
                      Visit us on facebook!
                      • sdmitchS
                        sdmitch
                        Please Sam?
                        Sorry guys but I see no possibilities. In fact it is impossible. Why, because the 'offsets' only work if all the angles at a 'corner' are the same. Plus, what do you with 'concave' angled corners?
                        • PixeroP
                          Pixero
                          In Thomthom's EdgeTools there is a script for manually diving faces called "Divide Face".
                          It have some clever ways of getting the "splitting edge" to match the face's surrounding edges.
                          Maybe if you took a look at how he does it there it might be possible to implement into your code?
                          • fredo6F
                            fredo6
                            Guys,
                            This is what Roundcorner does in the first place. So doable, but the code is not exactly concise and straightforward to catch all topological situations, especially those where the offset line don't meet at corner edges, as highlighted by sdmitch (just take an elongated pyramide for instance). Not mentioning concave corners and other complex geometry...
                            Fredo
                            • PixeroP
                              Pixero
                              @fredo:
                              So, when will your new version with all quad face corners be ready?
                              I believe you posted a sneak peak some time ago.
                              • JQLJ
                                JQL
                                That's a pity, but thanks fo the explanation. When rendering an architectural subject bevels make a lot of difference in image results and realism. However when working they are too cumbersome and when sending to Layout or CAD to document the building and dimension it, they become even moreof a nuisance.
                                Having some kind of temporary bevelling that you could toggle, loke subd, would solve the issue.
                                I guess a lot of us would find that an incredible tool and I thought, for a moment, it would be possible...
                                Even so,thanks for your time gentlemen!
                                www.casca.pt
                                • C
                                  cesaro36
                                  Hi guys
                                  This is what I came up with a few months ago, but it fails when curves or inner loops exist.
                                  Also it uses the offset.rb from Smustard(TM).
                                  By using this combination of soft and smooth you are able to put correct dimensions in both SKP and LO
                                  If you need to get rid of the changes the plugin Fix101 takes care of it.
                                  Any ideas to improve this?
                                  #CSR create soften edges for renders
                                  ss = Sketchup.active_model.selection
                                  Sketchup.active_model.start_operation("test")
                                  old_edges = []
                                  new_faces = []
                                  ss.each{|e|old_edges.push e if e.class == Sketchup::Edge}
                                  ss.each{|s|new_faces.push s.offset(-0.0625) if s.class == Sketchup::Face}
                                  old_edges.each{|oe| oe.smooth = true}
                                  new_faces.each{|nf| nf.edges.each{|nfe| nfe.soft = true; nfe.hidden = true}}
                                  Sketchup.active_model.commit_operation
                                  • PixeroP
                                    Pixero
                                    @cesaro36:
                                    After adding offset.rb it worked.
                                    However the old edges are hard and the new ones are soft.
                                    • JQLJ
                                      JQL
                                      Can anyone convert it to a plugin?
                                      www.casca.pt
                                      • PixeroP
                                        Pixero
                                        I'm trying...
                                        I think it would work better if it only operated on edges that are hard.
                                        How would one do that?
                                        • JQLJ
                                          JQL
                                          And do you think it could have a method for operating at render time or is it too slow for that?
                                          Like tag some objects and apply the effect when hitting Thea's render button and then undo it (using skatter's method)?
                                          www.casca.pt
                                          • PixeroP
                                            Pixero
                                            I don't know yet.
                                            It has some bugs as it's not working correctly on for example a cylinder with soft edges. And some other things that would need solving first.
                                            • 1 / 2
