    DOC MULTIPLE REFERENCE MODELS
    4 Posts 2 Posters 1.7k Views 2 Watching
    • J
      jonathonlt
      2nd post with helpful attatchment ,,if you no drafting (pencil & papper) then referring to many drawings as you progress a new one , is everything ,, I have tried opening SU multiple times,, this does work ,,yet switching from model to model or splitting the screen disturbs the perspective and has no work flow .Refering to the above image , could possibly allow fast accurate switching between models ,with LIVE floating model or models as having SU open many times,, Is this then the same as the OS ,having multiple docked files ( say FILE EXPLORER ) yet not having to open the OS many times. ( still learning ,,this post should possibly be in THE WISH LIST ,that I only saw after posting this ,,,AH ,,if I try and move it ,I PROBARBLY ERRASE IT ,,2 HOURS /WEEK only Jon..
      I am with su make ( it,s to free ,ease my consciense if they had £ 40 low income version )
      • jujuJ
        juju
        Hi Jonathon, which version of SU are you using?
        • J
          jonathonlt
          make 17 ,,just 3 months CAD ,ing,,,a lot to do ,,and not much reason to..if in orbit,,you will notice a large sign stuck into planet earth " private property ,,keep off" Jon..
          • jujuJ
            juju
            Sorry, I'm struggling to understand what you're getting to, I won't be able to help you.
            Please be sure to update your profile (it is currently showing you're working on SU7), this will help others in assisting you.
