    Weird DimensionLinear behavior
    5 Posts 3 Posters 2.4k Views 3 Watching
    • I
      ittayd
      Dimensions that are inside components change their texts based on the instance scale. This is true in the GUI as well as the API.
      For example, in the images below, the rectangles are instances of the same component. I open the left one, get a dimension entity and its text and then open the right one and get the text of the same entity which changed. A similar thing happens for positioning
      Is there a way to get all texts of the dimension instance? Is there a way of programmatically change one?
      (I'm using SU 17.2.2555)
      Left rectangle
      Right rectangle
      • D
        driven
        you can do things by comparing instance scaling...
        model = Sketchup.active_model
        defs = model.definitions
        insts = defs[0].instances
        insts.each{|i| p (i.scaled_size - i.unscaled_size)[0].to_mm if i.scaled_size != i.unscaled_size}
        john
        • Dan RathbunD
          Dan Rathbun
          As John explains you have to iterate the definition's instances collection, and apply the scaling of each instance's transform, to the value of the length between the start and end points (vertices.)
          dim_length = defn_dim.start[1].distance(defn_dim.end[1])
          The DC extension adds the yscale, zaxis, zscalemethods to the
          Geom::Transformation class.
          NO. If the dimension is a member of a definition's entities, changing 1 changes them all.
          I'm not here much anymore.
          • I
            ittayd
            Thanks, I'm asking about ways to interact with the text: getting, setting.
            • Dan RathbunD
              Dan Rathbun
              No this is not what you asked!
              Such a simple thing (as what method's a class has) can be easily found by looking at the API dictionary.
              http://ruby.sketchup.com/Sketchup/DimensionLinear.html
              ... which is a subclass of (and therefore inherits methods from😞
              http://ruby.sketchup.com/Sketchup/Dimension.html
              http://ruby.sketchup.com/Sketchup/Drawingelement.html
              http://ruby.sketchup.com/Sketchup/Entity.html
              http://ruby-doc.org/core-2.2.4/Object.html
              You asked about dims nested inside transformed instances.
              I am not sure if the .text getter will return transformed lengths or not. Also not sure what happens when the context is open and not. So test.
              The means I showed above avoids the conversion of text ( String) into a numeric ( Length) object, and just gets the length.
