    Uninitialized class variable
    5 Posts 2 Posters 1.2k Views 2 Watching
    • PixeroP
      Pixero
      I'm trying to make a script remember the values the user puts in during a SketchUp session so that he wont have to re enter them every time the script is run.
      When for example using:
      module Mymodule
        class Myclass
        def initialize
          #Setting default values
          @myvariable = 25.mm unless @myvariable
          #And so on......
      the script works but wont remember the settings when run again.
      When using @@myvariable = 25.mm unless @@myvariable
      I get a "Uninitialized class variable" error message.
      What am I doing wrong?
      • PixeroP
        Pixero
        Should it be @@myvariable = nil and then @myvariable with just one @ or was that a typo?
        • sdmitchS
          sdmitch
          I just copied your code and added the @@myvariable=nil to it. The typo, @myvariable, was in your original code.
          It should be @@myvariable everwhere.
          http://sdmitch.blogspot.com/
          • sdmitchS
            sdmitch
            module Mymodule
            >   class Myclass
            >   def initialize
            >     #And so on......
            You just need to make a dummy assignment to it just after class declaration.
            module Mymodule
              class Myclass
              @@myvariable=nil
              def initialize
                @@myvariable = 25.mm unless @myvariable
                #And so on......
            • PixeroP
              Pixero
              Thanks, that worked.
