    What to put on new SSD?
    3 Posts 2 Posters 6.9k Views 2 Watching
    • srxS Offline
      srx
      I need help from someone with experience in using SSD. I am in process of moving system files on SSD. The question is what to do with working files , project files, resources files, like components, materials, textures? To keep them on the old HDD or to move them on SSD? I understand that the problem is about speed and also about the amount of data write that SSD can handle. What do you suggest? Thanks.
      www.saurus.rs
      • srxS Offline
        srx
        Thank you. "My recent projects and presorted textures and models" on SSD. I will follow your advice. It is a good time to sort things out gradually...
        www.saurus.rs
        • N Offline
          numerobis
          I would say it depends on the size of the SSD, the amount of data and your data structure. Of course basically as much as possible of your work files on the SSD. Durability shouldn't be a problem at all at these data rates.
          I have all my data files (project files, documents, textures, models, materials, installers) stored on my file server. My recent projects and presorted textures and models on a 500GB SSD on the server (in RAID1). And the rest on HDD. All backuped to HDD. (so the network connection is the limiting factor)
