    Axes question
    8 Posts 2 Posters 2.2k Views 2 Watching
    • PixeroP
      Pixero
      I'm trying to understand how axes works and have a script where axes are set to a custom value. I create a face and a group and still the origin and axes of the group is the default origin and axes.
      Why doesn't it respect the new working axes?
      If I do it in the UI it works as expected and I get it to line up with the custom axes set in the script.
      I'm looking for a way of not having to transform everything back to origo to get group/component origin and axes correctly as this workflow has caused issues with certain values and rotation directions for me.
      I found the Sketchup.active_model.axes.set(origin, xaxis, yaxis, zaxis) and thought it might be possible to:
      First, store the current axes.
      Set origin and axes to some custom value.
      Then do stuff within the new origin and axes. (Like creating a face and group it and have groups and components to have their axis set correct.)
      And finally reset axes as they were before the script was executed.
      I got really exited about this and was hoping it could be a work around until we get proper set axes for components and groups.
      If done in the UI it works so why doesn't it within my script?
      • PixeroP
        Pixero
        Here is a small test script that describes what I'm after.
        Only that it doesn't align the created groups axis with the set axes. πŸ˜•
        Any ideas?
        Note that for this test I have hard coded some points and vectors.
        module JS
          class Axestest
            model=Sketchup.active_model
            entities=model.active_entities
            # First we save the current origin and axes so we can reset back to them when we are done.
            current_origin = Geom;;Point3d.new(model.axes.origin)
            current_xaxis = Geom;;Vector3d.new(model.axes.xaxis)
            current_yaxis = Geom;;Vector3d.new(model.axes.yaxis)
            current_zaxis = Geom;;Vector3d.new(model.axes.zaxis)
            # Debug
            puts current_origin.to_a
            puts current_xaxis.to_a
            puts current_yaxis.to_a
            # Now get the point for the temp_origin and temp_axes
            temp_origin = Geom;;Point3d.new(20, 10, 0)
            temp_xaxis = Geom;;Vector3d.new(1, 1, 0)
            temp_yaxis = Geom;;Vector3d.new(-1, 1, 0)
            temp_zaxis = Geom;;Vector3d.new(Z_AXIS)
            # Set the origin and axes to the temp_axes
            model.axes.set(temp_origin, temp_xaxis, temp_yaxis, temp_zaxis)
            # Do stuff here to (hopefully) "set" group/component axes correctly align with the object
            pt0=Geom;;Point3d.new(10, 20, 0)
            pt1=Geom;;Point3d.new(20, 30, 0)
            pt2=Geom;;Point3d.new(20, 10, 0)
            pt3=Geom;;Point3d.new(30, 20, 0)
            group=entities.add_group
            entities=group.entities
            base=entities.add_face(pt0, pt2, pt3, pt1)
            # At the end reset the axes
            model.axes.set(current_origin, current_xaxis, current_yaxis, current_zaxis)
          end#class
        end#module
        • PixeroP
          Pixero
          No one?
          • PixeroP
            Pixero
            I solved this problem by doing it a bit differently. I set the axes to the temp axes and then create all geometry and groups/components at original "world" origo and then at the end used
            tr = Sketchup.active_model.axes.transformation
            to transform the component to the temp axes and finally revert axes back to what it was before.
            Maybe it's an unorthodox way of doing it but I found that by creating everything at world origo it was much easier to add stuff. And it works well with all components axis set perfectly. β˜€
            Here is a small test script that shows the process if anyone is interested.
            module JS
              class Axestest
                # Now get the point for the temp_origin and temp_axes (Hardcoded for this example)
            	# Point for a rectangle.
                points = [
                  Geom;;Point3d.new( 0,  0, 0),
                  Geom;;Point3d.new(10,  0, 0),
                  Geom;;Point3d.new(10, 20, 0),
                  Geom;;Point3d.new( 0, 20, 0)
                base=entities.add_face(points)
            	# Transform the group/component so that it is local to the temp axes.
                group.transform!(tr)
              end#class
            end#module
            • Dan RathbunD
              Dan Rathbun
              You might have missed the fact that the virtual helper classes Point3d, Vector3d and Array, can be transformed.
              So if you were not creating a group, you could do before actually creating the geometry:
              points.map! {|pt| pt.transform!(tr) }
              For a group, you can actually apply the transform to the group, before adding the geometry. (You might need to assign a temporary cpoint to prevent SketchUp from garbage collecting it, as is normal.)
              This will prevent the users from seeing geometry appear in a strange place.
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                Only the native tools respect the custom Axes setting by default.
                If they had suddenly changed the API so that ALL code creating geometry in model space used the custom axes, they'd have broken a multitude of extensions, causing havoc.
                Another facet, is that the original model origin and axes actually remain unchanged.
                So, anyway, they decided that coders themselves had to decide to honor the user's custom axes settings.
                • Dan RathbunD
                  Dan Rathbun
                  Add coming from all this would be the need to detect when the user changes the axes:
                  # encoding; UTF-8
                  # A simple Axes Observer to detect when a user changes axes.
                  module Author
                    class AxesSpy < Sketchup;;EntityObserver
                      @@instance ||= self;;new
                      def self;;attach( mod = Sketchup.active_model )
                        mod.axes.add_observer(@@instance)
                      def onNewModel(mod)
                        self;;attach(mod)
                      alias_method ;onOpenModel, ;onNewModel
                      def expectsStartupModelNotifications()
                        true
                      def onChangeEntity(ent)
                        puts "AxesSpy; #{ent.inspect} changed."
                      Sketchup.add_observer(@@instance)
                  • Note that the Axes object was first exposed with SketchUp 2016.
                  Edit: Fixed alias_method call. args were swapped, in error.
                  (I always seem to get them backwards. I always think "alias this as that", but it is more like "newalias that of this".)
                  πŸ€“
                  • PixeroP
                    Pixero
                    Thanks for the info.
