    Problem with Compound from CD on Curvy faces.
    3 Posts 2 Posters 8.8k Views 2 Watching
    • E
      Europa
      When I draw complex objects like curved cams I see that compound from CD is not working properly. I see some leftover lines when I check with collision wireframe. What can I do about it. A sample picture is attached?
      The cam model is mirrored and grouped as single.
      • A
        Anton_S
        Yes, Compound from CD shape is unstable. You can use a plugin by Fredo6, called convexy, to divide the green piece into convex sub-groups. And also change the shape to Compound. Here it is: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61145
        • E
          Europa
          Thank you Anton.
